Courtesy lighting wiring.
Old Mar 26, 2018 | 06:30 PM
Screwed 05's Avatar
Screwed 05
I am adding some led strips under my doors on the outside and led strips under the front buckets. I'm looking for these LEDs to light up when the dome lights come on via using the key fob or opening the doors. The only thing I can find is that the wires I have to tap in to runs along the rear passenger side door. Can anyone tell me which wires/ color I need to splice into? This is on a 05 f150 xlt supercrew.
Thanks in advance.
Old Mar 27, 2018 | 11:07 AM
alloro's Avatar
alloro
I would tap into the wire for the exterior mirror puddle lamps. You will find a BK/LB wire going to each door and that should be the correct wire.
Old Mar 27, 2018 | 01:47 PM
Screwed 05's Avatar
Screwed 05
My truck doesn't have the puddle lamps. Thanks thou.
Old Mar 27, 2018 | 05:59 PM
Franklin2's Avatar
Franklin2
Black/lightbue is still the wire you need to look for. Poke it with a testlight before committing to make sure you have the right wire.
Old Mar 27, 2018 | 06:32 PM
Screwed 05's Avatar
Screwed 05
Would that be running along the passenger side rear door? There should be another wire maybe it's a ground.
Old Mar 28, 2018 | 05:56 AM
Franklin2's Avatar
Franklin2
I am not sure were the wiring is located, but that color wire should be serving any light that illuminates when the door is open (courtesy lights).
Old Mar 28, 2018 | 10:26 AM
alloro's Avatar
alloro
Doesn't matter the wire is still there.
Old Mar 28, 2018 | 10:31 AM
Screwed 05's Avatar
Screwed 05
Ok thanks.
Old Apr 3, 2018 | 06:14 PM
Screwed 05's Avatar
Screwed 05
Update. The install of the entry lighting is done. I found on the driver's side harness that runs under the scuff plates. The black w/lt blue worked great. The passenger side was not so easy the black w/lt blue was dead (no power) and the light green w/orange was constant hot. So ended up running all the lights from the drivers side harness. Thanks for the help.
Screwed 05
2004 - 2008 F150
Mar 26, 2018 07:13 PM
2006SDpower
Sep 14, 2010 01:51 PM
tg150
Electrical Systems/Wiring
17
Jan 31, 2008 10:45 PM
schmidt64
Oct 26, 2007 01:44 AM
svtgtcobra
1978 - 1996 Big Bronco
Dec 20, 2004 01:40 AM
