Key Tumblers
Old Mar 26, 2018 | 01:21 PM
pchelp's Avatar
pchelp
Key Tumblers
What has everyone done to match replaced door tumblers to the ignition tumbler so they all work with one key?
Old Mar 26, 2018 | 01:32 PM
JEFFFAFA's Avatar
JEFFFAFA
I know how to reset the tumblers to match another key. But I bought mine as a set. There is prolly a You Tube on how to do it. If not, a local lock smith should be able to do it.
Old Mar 26, 2018 | 01:59 PM
69 cjshaker's Avatar
69 cjshaker
Any locksmith can do this. The pins are pretty much universal between 99% of locks, so it's an easy job. There's a locksmith that works where I work and I have him do all my stuff. Home, auto, you name it. He has it done quickly, and he makes them so that they're more difficult to pick by using pins that vary greatly in depth.
Old Mar 26, 2018 | 03:00 PM
pchelp's Avatar
pchelp
Ahhh yes, I can do this !
Old Mar 26, 2018 | 03:23 PM
JEFFFAFA's Avatar
JEFFFAFA
That picture is of a later model Ford style lock cylinder. Totally different tumbles that the old style locks we have. Our locks have a 2 piece tumbler set up. 5 tumbler sets per lock because there is 5 cuts in the key. The 1st half is a spring seat and the 2nd 1/2 is what touches the key. Both halves are different lengths to make a different "code" for that cut position in the key. There are 5 depth codes. # 1 is the shallowest and the key is just barely cut. All the way to #5. Which is the deepest. Example picture below. Can you see the cuts (divots) in the key? Without having that key in my hand, I think there are #4,#2,#1,#2, then #5 cuts in it. Starting at the head of the key. And matching tumblers inside of course.
Old Mar 26, 2018 | 03:35 PM
pchelp's Avatar
pchelp
I am always amazed by the amount of knowledge and experience on here !
Old Mar 27, 2018 | 08:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Looks like 5 - 2 - 1 - 2 - 4 .. What does the FA code translate to?
Actor Lorne Greene (Bonanza) bought a new '85 Town Car, wanted 8 sets (!!) of 10 cut keys. The electric key cutter was broken, so I had to cut them w/a Curtis hand held key cutter. What a b!tch that was!
Old Mar 27, 2018 | 02:03 PM
JEFFFAFA's Avatar
JEFFFAFA
I dunno. This Dealership doesn't have a Curtis key machine and it's code book anymore.
mickpowell1967
Oct 25, 2018 11:17 AM
F-6Flathead
Feb 4, 2009 11:14 PM
taylormade99
Dec 17, 2005 01:07 AM
K2JJB
Jun 4, 2004 09:22 PM
timmyjoe
Mar 2, 2004 08:19 AM
