I got my 2000 Explorer Sport back in june 2003.
Got from a Ford Dealer.
This is a stupid question my key dosent unlock my two front doors but it does unlock my rear hatch door is this normal ?
Can someone help me out before i call the dealership and make a *** of myself.
just an idea....... I watched the locksmith with my 99 exp. i had no keys when i bought my truck, bought at an auction. he put the key into the lock, and tapped it quite hard with a pair of pliers.... thought he was wierd. a good hard tap, and the key worked fine. he did the same with the ignition, surprised but happy..... good luck
Its the tumbler, the casing has a tendency to bind, causing the pins in the key way to stick...buy some lithium grease in an aerosol can(comes with a straw) and spray some into the key way then insert the key and work the key left to right up and down until the key is able to turn.
Ive never had a problem with the ignition but i would be a lil skeptical about hammering anything into the ignition key way.
like I said... it wasn't my idea to tap the key, it was the locksmith.... It took him 1/2 hr to cut and program 3 keys, he gave me 3 remotes and programed them too....and charged me way less than $100. The guy was alittle different, but he knew what he was doing, can not complain about his service.......
not recommending tapping away, but with the factory cut key from the dealer was not working, until he did that.... just the facts...........
Originally posted by 98txexplorer buy some lithium grease in an aerosol can(comes with a straw) and spray some into the key way
I would NEVER put Lithium Grease into a lock!!!!(It is way to heavy) Use graphite it's a dry powder and it won't allow dust to stick to it making matters worse!!!You can buy an applicator made just for locks at most auto supply places thats made just for this (1 or 2 squeezes will do it). If you absolutly have to use a liquid spray use WD-40 and use a VERY little bit! Anytime you put oil into a lock your asking for problems!!! The only person that would readily recomend using any oil in a lock would be a locksmith.....HEH....HEH
I would not recommend using graphite. Graphite is a form of carbon (as are diamonds) that forms hard plates (but not as hard as diamonds). The plates are very slippery when on flat to a surface and very abrasive when on edge to a surface. It's the abrasiveness that's a problem over time with locks. Back in the '60's and early '70's I remember graphite being very commonly used in locks. Then people quit using it because over time it abraided the internals. I haved used a thin spray oil that has microscopic particles of teflon suspended in it. This seems to work well as it offers penetration with the thin oil, and longevity from the teflon particles.
Oil attracts dust and dust clogs..........Graphite is an abrassive (as most things are) but be-bopping down the highway (or off-road)with oil in your locks is asking for problems and dust sticking to the pins etc... in a lock would be MORE abrassive in the end (IMO)but hey........It's America and we can all do as we like!
