Locks, Ignition and Keys
Old Dec 15, 2005 | 12:42 PM
taylormade99's Avatar
taylormade99
Hi all, I've been having problems with my key intermittently not turning my door locks. It works fine in the ignition, but sometimes I have to jiggle it around to get my door locks to work. I was thinking the locks themselves might be worn, but now I'm thinking its my key. I've taken my locks out of my doors and completely cleaned and lubed them and they did not appear to be worn whatsoever. Looking at my key, it appears to be worn significantly. I had a spare made and it acts almost exactly the same. Once again I thought maybe the locks, but then came to life and realized the spare that was cut is just going to follow the same "worn" pattern as my main key.
The question: Would the dealership be able to get me new keys based on my VIN or am I looking at a complete lock/ignition/key set replacement.
Old Dec 15, 2005 | 12:56 PM
stroker2's Avatar
stroker2
I'm interested in this question too. Got the same problem. Have the spare key from when I bought the truck that I only use if I lock the truck when I leave it running and both do the same thing. Work OK in the ignition but not on the door locks. Passenger side door lock is not used very much and same problem with keys. I read one time of someone getting a new key from the dealership and fixing the problem. I assumed it was made new using the VIN # or key number, I just haven't got around to getting it done. Would like to know for sure before I buy an expensive key from a dealership.
Old Dec 15, 2005 | 01:45 PM
SpringerPop's Avatar
SpringerPop
Take your worn key to a genuine locksmith. Drive your truck there so you can check results immediately. Tell him you have a worn key and you want him to either "clip" a key, or make it with his "code" key machine.
Either method should get you a key that has the depths of cuts that were originally on the key.
He'll measure your old key, take into consideration the amount of wear, and determine what the cuts need to be.
He should actually be the locksmith, not some kid working in the shop as an appretice.
Yes, it will be a lot cheaper than the dealer, especially if you can provide him with the Ford key code. It may be written down in your Owner's Manual, as some dealer salesmen have a habit of doing that as a service.
Pop
Old Dec 15, 2005 | 05:11 PM
taylormade99
Pop
Thank you. This is what I was looking for. I've never had key problems before so I didn't realize a locksmith had this capability. Learn something new everyday!
Old Dec 15, 2005 | 05:42 PM
stroker2's Avatar
stroker2
Pop
Yeah, but will it have the black plastic grip with the Ford logo? LOL
Just kidding. Thanks SP, I sometimes forget about those independent individuals trying to make a living, i.e. locksmiths.
Old Dec 15, 2005 | 06:00 PM
SpringerPop
Yes, the independant locksmith can provide you with a logo'ed rubber-bowed (a "bow" is the part of the key you hold between your thumb and forefinger) key if that's important to you. He may want to first cut a cheaper blank, to make sure he has the right code before cutting it onto the Ford one, but it all can be done.
Though I don't do it for a living, I am a State of California-licensed locksmith. LCO-604, to be precise. It was a fun avocation, but you don't want to be doing ANY work in the field without a license. It's basically a fingerprint and background check. So, I have a license, but don't know squat about automotive lock work, which is a pretty specialized field with lots of very specialized (read expensive) tools.
Pop
Old Dec 16, 2005 | 06:57 PM
thefonz#1's Avatar
thefonz#1
Springerpop, I knew you was a locksmith before I got that far along in your post.
I wish people would consider the locksmith more often. We are usually cheaper than the dealer or mechanics. Most dealers bring there stuff to us and double or triple charge the customer.
They can usually give you a pretty accurate estimate before they do anything.
But like all professions there are good and bad, and yes he can code out a key to factory specs. usually anywhere from $5.00 to $10.00 bucks plus the key would be a fair price.
Old Dec 17, 2005 | 01:07 AM
SpringerPop
Isn't THAT the truth!!! You get it done right the first time, and usually pay less by using the REAL professional.
Pop
Bubba Jones
1978 - 1996 Big Bronco
Mar 28, 2016 07:40 PM
mnkeeking
15
Nov 26, 2014 11:28 AM
ridealong34
Jan 27, 2014 11:01 AM
BruteFord
Dec 22, 2013 09:53 AM
jmadsen
Sep 21, 2011 11:34 PM
