Break Lights Not Working
Old Mar 26, 2018 | 08:27 PM
Filthy Beast's Avatar
Filthy Beast
Have to agree with Hickory1991 here: Check for power at the brake light switch and for correct play/adjustment. If all is well, chase the wires down to where they might be pinched/frayed/shorted.
Old Mar 27, 2018 | 11:26 AM
1978f-250's Avatar
1978f-250
Originally Posted by Casey Hope
I have a 75 f-250 and all lights on my truck work healight,turn signals, and park lights exept hazards in the back and break lights for some reason. Any help would be appreciated.
I wish I knew more about brakes so I could help you but that's the breaks.
Old Mar 27, 2018 | 12:36 PM
dlburch's Avatar
dlburch
since your rear turn signals work, that eliminates rear bulbs, grounds, sockets and wiring from the steering column connector...assuming the hazard flasher is good, you most likely have an issue in the turn signal switch...
70runner
Nov 4, 2012 01:27 PM
zacm7
Oct 12, 2012 02:30 AM
ezhd232
1997 - 2003 F150
Feb 6, 2008 07:39 PM
jrc
Sep 21, 2001 02:08 PM
ms
Feb 23, 2001 06:56 AM
