Sponsored by: Auxito
ABS issue
Old Mar 24, 2018 | 10:27 AM
blue76's Avatar
blue76
ABS issue
2001 supercrew 5.4. When coming to a stop less than 5 mph the abs kicks in. Im not getting abs light or codes. I've repalced all the abs sensors. Still have same issue. Not sure what else would cause the problem .
Old Mar 24, 2018 | 10:57 AM
pdqford's Avatar
pdqford
Did you check for a loose wheel bearing? Sometimes a loose wheel bearing will allow the tone ring to move sideways a smidgen as you come to a stop and the ABS losses the wheel speed sensor signal. It thinks the wheel is sliding and energizes the ABS. Makes it difficult to stop from 5 mph with the ABS engaged.
Old Mar 24, 2018 | 01:47 PM
blue76's Avatar
blue76
Just finished checking the hub. There is play in the bearing. I'm guessing thats what it is. Got a new hub ordered. Thanks for the tip!
Nathan511
1997 - 2003 F150
Mar 23, 2018 03:50 PM
edsheridan
Aug 25, 2014 02:39 PM
Diesel 724
May 11, 2012 04:53 PM
nlemerise
Aug 30, 2007 12:58 PM
RushN350
May 23, 2006 08:08 PM
