Has anyone put a NP 242 in a bullnose?
I had a limited slip put in a 1994 F250 I used to have and did not like it. The way I understand it is, if both wheels are on a slippery or a dry surface, both wheels get power. If one is on a slippery surface and the other is not, the wheel on the slippery surface gets the power.
If I was plowing like you are, I would go with what you have and "lunchbox lockers", they are a sort of inexpensive weak point if you will, and from what I understand easier to change. I would think with all four wheels pushing you would do well.
I bet you keep busy, plowing is rough on equipment!
The last company I worked for had a 1990's Chevy heavy half, I convinced my boss to put a Boss plow on it that fully articulated. Nice plow, needed more truck!
If I was plowing like you are, I would go with what you have and "lunchbox lockers", they are a sort of inexpensive weak point if you will, and from what I understand easier to change...:
The problem with a lunchbox locker in this case is that you need an open diff carrier to install one. So by the time you get an open diff, install it, and install a lunchbox you are at the cost and difficulty of installing pretty much any diff. For a plow truck rear I'd use a Truetrac, But a full carrier automatic locker (like a Detroit or Grizzly) wouldn't be a bad choice either. And some people really like selectable lockers (like an ARB, OX or e-Locker). Then again, keeping the factory limited slip and being glad that it's so worn out that it doesn't hurt stability much isn't necessarily a bad option either.
With the weight of the plow on the ground, I wonder how the power would transfer to the 4 wheels? It might be interesting. With the plow up, I am pretty sure most of the power would transfer to the rear wheels and they would spin when the going got tough. But it may be different story with the plow on the ground.
You're correct Franklin, that's the exact problem. I think most of the time the open center diff would be fine but as you say when the going gets tough I could just lock the center because if it's slick enough to need the center locked I doubt it'll bind up then.
From what I've found so far, the T19 has a stick out of 6.5" where the GM version of the NV4500 has a 6.675" stick out, that should work if I can just re-drill the pattern on the T19 bell housing with a .125" spacer, If the pattern on the NV4500 is to wide to go on the T19 bell housing then the Dodge version of the NV4500 has a stick out of 7.625 so I could make an adapter that's 1.125" thick and find a clutch to work. From my reading the 242 either fits the NV4500 or is easily adaptable.
This might just turn out to be feasible.
The only way to get a np242 in your truck without having custom adapters made would be to swap an NV4500 transmission in your truck ( there is also some 4 speed manuals that will work) along with an adapter kit from advance adapters to adapt it to the 23 spline input. The adapter is around $300 then you would most likely have to have custom driveshafts made. The np242 is a good case I have one in my Jeep but it would be expensive to make it work in your truck.
I'm not looking for more traction, I have issues with drivetrain binding when turning around. which is why I would like the full time mode. I'd still have the part time locked center for those times I need it. So far I haven't had a problem with traction and I even plow uphill on the steep stuff. The road I plow is about 1.5 miles with 1000' elevation change plus about a half mile of county road to get us out to a road the county plows. It's not a problem when there is a good base of snow and ice but when cleaning up after the snow I'm running on a combination of wet pavement and snow which I think the full time setup would be much better at.
I'll have to look into and hopefully try one of those so I can learn about it. That's a lot of plowing with elevation!
I didn't find any adapters to fit anything on the ford 6.9 so I think this is the best approach so far. I've found a couple bolt pattern drawings for the T19 and the NV4500 but none of them reference the crank/input shaft center-line in the measurements so I'll either have to get a tranny to measure or get lucky and find one for both trannys.
Thanks
for all the input guys.
Do not know if it will help any, probably not. But the 6.9 and 7.3 idi engines are international built engines with their own oddball international bellhousing pattern. Ford made a bellhousing adapter to adapt it to another oddball pattern they dreamed up, way to go Ford. So there is actually an adapter on your engine already. Why they did not adapt it to a 460 pattern I will never know. But, they also make an adapter for these engines to a SAE pattern. This is a big truck pattern, and you can find these adapters on school bus engines, u-haul engines, and these engines when they were in dump trucks and other heavy equipment.
That is a good question on why they didn't use an existing bolt pattern, who knows what drives that kind of decision. So far I haven't found any references to the NV4500 being used in bigger trucks, not a lot of info that I've found about application other than Chevy and Dodge pickups. The grand kids go home today so I can continue searching.
highrider76
02-04-2004 04:15 PM
Custom 1975
08-12-2003 02:08 PM
jayjayem3
06-10-2003 11:02 AM
