I have a 76 f250 with a full time divorced transfer case. If i put a part time kit in it. wiill it
A. weaken the tranfer case.
B can i still run in 4wd but not in the lock position.
C. WIll this improve fuel ecomnomy.
will just putting lock out hubs on help fuel economy?
is that hard on driveline parts?
It was a good case for Me I had a 203 with a part time kit until I blew the differential out thru the tail shaft case, I've talked to a couple 4X shops and they said the conversion was fine unless you get on it alot (My Problem) now I have a 205 which was a direct bolt in except for the front and rear drive shaft lenght....
