Engine oil cooler replacement
Old Mar 22, 2018 | 08:16 AM
Tissue0521's Avatar
Tissue0521
I have a 1997 F250 with a 7.3L. I currently have an o-ring leaking on the oil cooler and I’m thinking about replacing it while I have it out since it has 297,000 miles on it. Any recommendations on what to go back with? Motorcraft is preferable I’m sure, but I have heard some performance parts are higher quality with a cheaper price tag. Haven’t been able to find much information on it online. Anybody have some experience with this?
Old Mar 22, 2018 | 09:15 AM
oldbird1965's Avatar
oldbird1965
I got mine from Riffraffdiesel.com, at the top of the main page.
Old Mar 22, 2018 | 11:02 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
Why not just reseal the thing? I spent about $60, I think, in OE seals including the block gaskets, easy.
At 300k you are pretty much going to need every oil seal on the truck...just about finished up doing this to mine. 1994-1998 Ford 7.3L
Old Mar 22, 2018 | 11:55 AM
97-psd's Avatar
97-psd
Old Mar 23, 2018 | 12:35 PM
captnjoe's Avatar
captnjoe
I just did this project. Make sure you are using Ford OE seals! After using some "quality" aftermarkets, I got to spend 2 days getting 2 gal of oil out of my cooling system. Yea, the inner seal failed right off the bat, and it takes about 2 minutes to pump all your oil into your cooling system when you test idle for leaks.
So after using all four letter words in the English and Italian language, I went and got some Ford seals. The fit was noticeably tighter, and the compound softer. This time the job went easy peasy. Moral of the story, use only Ford OE seals on this motor!
Old Mar 23, 2018 | 02:12 PM
Sir_Captain_Obvious's Avatar
Sir_Captain_Obvious
Thank you for this
Old Mar 23, 2018 | 11:04 PM
oldbird1965
Use a 50/50 mix of oil and vaseline on the O rings.
Old Mar 24, 2018 | 07:54 AM
Shawn MacAnanny's Avatar
Shawn MacAnanny
Use a silicone oring lube instead of Vaseline. Vaseline breaks down in the 140f range. Silicon oring lube is good to 400f so it protects the orings and the housing imperfections for its life
1310476 Molykote Valve Lubricant and Sealant 5.3 oz. Tube https://www.amazon.com/dp/B00IKUIO82/ref=cm_sw_r_cp_api_rPKTAbQ307TTX
Old Mar 24, 2018 | 12:00 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
1310476 Molykote Valve Lubricant and Sealant 5.3 oz. Tube https://www.amazon.com/dp/B00IKUIO82..._rPKTAbQ307TTX
Great info!
fordmerc
Modular V10 (6.8l)
Dec 27, 2017 08:23 PM
Macmathews
Jul 11, 2016 10:43 PM
Eddillard79
Apr 18, 2014 06:42 PM
Jeremy2792
Nov 7, 2013 10:03 PM
fuelman
Dec 10, 2009 07:44 PM
