Ignition upgrade help
Old Sep 17, 2003 | 02:47 AM
fordman777's Avatar
fordman777
Cool Ignition upgrade help
Hey guy's just have a question for you where can I get msd ignition parts at for my Sweet 91 F-150 4.9L.
P.S. I just had a $3000.00 paintjob on her she is one of the best looking F-150's in town, I have over 15000.00 in her and counting. Will have a couple of pictures soon!!!!!!!!!!!
Thank's Ford's Rule and Chevy's Drule!!!
Old Sep 17, 2003 | 07:06 AM
jwtaylor's Avatar
jwtaylor
You can get msd ignitions from anywhere probably your local auto parts store if not then jegs and summit. Two things to definitely do when you get the msd. Keep it away from any excessive heat and get/use the vibration mounts.
http://www.jegs.com
http://www.summitracing.com
How about you put some pictures of that $3000 paint job in your gallery. Later
Old Sep 17, 2003 | 10:12 AM
fordman777's Avatar
fordman777
I have already tried to get an msd system but the parts store told me that they don't make msd systems for a 4.9l, and I can't find it anywhere on the internet.
Thank's
Old Sep 17, 2003 | 10:58 AM
jwtaylor's Avatar
jwtaylor
Well they are crazy. Call summit or jegs, the msd box has no idea how many cylinders your engine has all it does is control the spark. You will need to get msd wires or equivalent the solid core stock type will not work properly. Later
Old Sep 17, 2003 | 12:12 PM
stractor's Avatar
stractor
Hi, You will need the following
1. MSD 6A Ignition Box This box doesn't care what you have.
2. MSD Ford TFI Coil or one of the other ign makers TFI coil, I have an ACCELL TFI coil on an MSD box. Gives 50k volts
3. Optional----Plug In~ coil to box to oem harness-- wire harness MSD or others. This saves cut and splice headaches.
4. Really good 8mm plug wires
5. New Dist cap and rotor
stractor
Old Sep 17, 2003 | 12:40 PM
fordman777's Avatar
fordman777
The parts store said that they can't get the msd distribitor & cap or the plug wires for a 4.9l. I wen't to the summit, jegs, and msd sites and I ain't having any luck.
Thank's
Old Sep 17, 2003 | 01:46 PM
stractor's Avatar
stractor
MSD doesn't make a cap and rotor, sorry about that. I meant to say that you should use a new OEM cap and rotor as the system will put out 50k+ volts far more than the original. An old cap and rotor might not handle the voltage due to dirt , grease or carbon build up.
stractor
Old Sep 17, 2003 | 04:48 PM
fordman777's Avatar
fordman777
I just got back from the parts store and bought a accel universal 12 volt coil but I don't know how or where to mount the new coil it isn't going to fit in the factory mount, even though it is a universal could it not fit.
Thank's
Old Sep 17, 2003 | 10:53 PM
stractor's Avatar
stractor
Hi, take the coil back. You will not be able to use it.Don't try to make it fit. It is most likely rated to put out far less than the stock coil. Ford uses a _____TFI coil____. If you are going to do this do it right and order the parts from either Jegs or Summit, forget the local auto store. He will not have what you want. Use your computer and look up the MSD website, you want an MSD 6A box and Ford TFI coil, look them up. The project will cost you around $175. If not leave the stock system in place and do a good tune up, because you are going to go backwards.
stractor
Old Sep 17, 2003 | 11:52 PM
GeneStoner's Avatar
GeneStoner
Another option for you...
Mallory Unilite and an Accel Super Coil on a custom mount.
Old Sep 18, 2003 | 12:12 AM
stractor's Avatar
stractor
Real nice Job Gene , does it glow in the dark when it is running?? The neighbors TV set must love it. I will bet you can remove the side electrode from the plugs and have it arc to the head , hard to gap though.
Just kidding , nice engine.
stractor
Old Sep 25, 2003 | 05:36 PM
fordman777's Avatar
fordman777
Thank's for all the help guy's I got It all straightened out, again I really appreciate all of your help.
tom18287
1997 - 2003 F150
16
Dec 12, 2016 07:28 PM
12manycars
Oct 2, 2016 10:57 PM
cnobles10
Nov 4, 2015 02:54 PM
cnobles10
Oct 20, 2015 08:03 AM
david00f150
Oct 9, 2006 09:20 AM
