Sponsored by: Real Truck
Transmission 1st start
Old Mar 21, 2018 | 08:45 PM
Lawnpro979's Avatar
Lawnpro979
On my, 2000 SD V10 the 1st start in the morning, the transmission won’t engage in drive.
I have to pull the shifter down to L, then take off, then I shift it to D, and it’s fine.
there is no rough shifting or any other issues, and it’s fine for the rest of the day.
its only after it’s sat overnight...
I changed fluid and filter a few months ago. It seemed to help for a little while.
Old Mar 21, 2018 | 09:59 PM
fordmerc's Avatar
fordmerc
Check the fluid level while warm. Add if needed.
Old Mar 22, 2018 | 02:50 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Check the fluid level when cold BEFORE starting the engine. If it is very overfilled it is because the torque converter is draining into the pan. There is a valve in the pump body that should prevent this. If it gets stuck or leaks the converter can drain. When it's really low on fluid it can't transmit torque and you don't go anywhere. Maybe moving the shift lever to 1 is just enough extra time for the converter to refill.
Old Mar 22, 2018 | 04:38 PM
Lawnpro979's Avatar
Lawnpro979
It started it about a year ago....the fluid level is fine
I changed fluid and filer thinking it would help but no help....
Old Mar 22, 2018 | 08:00 PM
Mark Kovalsky
What does the fluid level look like after it's sat overnight and BEFORE you start it?
Old Mar 22, 2018 | 08:12 PM
Lawnpro979's Avatar
Lawnpro979
haven’t checked, but thx, will check in morning,,,
dogdays
2004 - 2008 F150
18
Jan 10, 2019 05:15 PM
fr420
Aug 4, 2016 08:57 AM
tunruh
Aug 6, 2008 05:04 PM
jdn159
Nov 18, 2007 05:54 PM
bohiaa
May 10, 2006 08:08 AM
