Need Transmission help for '95 E150
Old Jul 30, 2016 | 11:39 AM
fr420's Avatar
fr420
I just did a fluid and filter change on the transmission. Put it all back together, filled with fluid. Ran it to check level and now it will not go into any gear. Could I have done something? What can I look for?
Old Jul 30, 2016 | 03:29 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Obviously you did something wrong.
Did you drain the torque converter, or just the pan? How much fluid did you put in it?
Old Jul 30, 2016 | 08:19 PM
baddad457's Avatar
baddad457
And which transmission is it ? The E4OD holds nearly 4 gallons of fluid if you drained the torque converter.
Old Aug 1, 2016 | 05:15 AM
fr420's Avatar
fr420
No, I did not drain th te Converter. It was short fluid. I started off filling it cold. I originally thought i overfilled it while it was cold. So i started truck to get it hot and check it hot, but also wanted to back the truck up to clean up my mess underneath, but couldnt get it to go anywhere and i panicked. To be honest, i never knew that being low on tranny fluid could cause it to not go i to gear at all
Old Aug 4, 2016 | 08:57 AM
Mike1's Avatar
Mike1
Did you figure this out yet? Did you put back in just as much fluid as you drained? Did you install the filter wrong?
bohiaa
15
Oct 6, 2017 06:46 PM
bohiaa
May 10, 2006 08:08 AM
ParisDakar
Sep 2, 2004 10:58 PM
wgm114
Oct 25, 2001 04:41 PM
