Sponsored by: Auxito
ABS light
Old Apr 13, 2010 | 12:41 PM
justin_pistol's Avatar
justin_pistol
ABS light
hello all,
Maybe someone could help me out a little here, you guys have soooo helped me out in the past THANKS
TRUCK- 1997 F-150 4x4 5.4L 180,000 miles ( great truck )
ok. The ABS light came on yesterday and wont go off.
I did a search and read of some other guys with same problem so I checked all the wires I could see from under thr truck (looked good)
Then I replaced the rear diff abs sensor ($13.99 autozone special) no help. The omhs on the old one was 1200 and i guess that is in range.
The light comes on when I start along with the 4x4 and low range light the 4x4 and low light go off and ABS flickers and comes right back with the truck still in park.
Where are the front wheel sensors and how hard are they to get at? Can they be tested , fixed, or replaced from a junkyard? Autozone wanted something like $169.00 for one.
Thanks in advance for and advice or information, you guys rock
Old Apr 13, 2010 | 06:24 PM
Ultramagdan's Avatar
Ultramagdan
I would have a ABS code reader put on it first. It will keep you from chasing parts.
Old Apr 14, 2010 | 08:43 AM
justin_pistol
where would I find a abs code reader? and does it plug into the same port the regular code readers?
Thanks justin
brakes work fine its just the light being on all the time sucks. Right now everything on the truck works like new and I dont want to start letting things go.
Old Apr 14, 2010 | 10:41 AM
Ron W.'s Avatar
Ron W.
The better ( read more expensive ) scan tools will read ABS, SRS and trans codes, how ever if you're looking for a cheaper one like I was google " autel us703 " got mine for $156 through amazon.
And yes it plugs into the same port.
Oh and I'm sure there are other brands out there that will do the job as well or better.
Old Apr 14, 2010 | 03:15 PM
xxl_2321's Avatar
xxl_2321
the front sensors are on top of the hub bearing assembly rite behind the the brake rotor shield. they are held on by one allen head bolt
Old Apr 14, 2010 | 04:03 PM
justin_pistol
ok I got a cool dude at a repair shop to read my codes
C1155 LF speed sensor input circuit
C1185 ABS power relay output
any ideas were to go from here???
I'm thinking check the relay first because easyer to get to
could a bad relay cause a speed sensor failure code? (fingers crossed)
any input would be great
ok I looked for the ABS power relay and all I found in the fuse box was a 5A fuse ( good) to 4WABS module and relay.
then I looked in the power dist box and all I found was 60A fuse (good) to 4WABS/rear anti-lock and a diode for rear ABS.
I can't find the ABS power relay.....can someone help me here?
Chilton says "the control unit for RABS is located in the dash" and " the control unit on 4WABS is called Eelctronic hydro control unit (EHCU) is located inside the engine compartment"
Can someone tell me were this thing is?
My truck coded :ABS power relay output: is this what it is refering to?
ok, can't find the relay so lets check out the LF speed sensor.
I pulled the wire conector to the LF senor inside the engine compartment and tested ohms....open circuit.
Is this the cause of my ABS light staying on?
Old Apr 14, 2010 | 05:41 PM
justin_pistol
anyone parting out a truck and want to sell me one they are $159.99 at the autozone
Old Apr 18, 2010 | 06:49 AM
wedge40's Avatar
wedge40
I'm just starting your process. My light comes on and stays on. The brakes work, but not ABS. I looked at NAPA and they have two versions of the ABS sensors for sale. One looks pretty cheap, $46.00 and the other is $150.00. I don't know if my code reader will check the ABS, but if not I'll get the code and go from there.
Not sure if salvage yard will sell a used sensor since this is a safety device
UpDate: Here is what I found out today. I push the brake to start the truck. If I keep my foot on the brake after the truck starts, the ABS light will go out. Once I take my foot off the brake the ABS light comes on and stays on.
Wedge
Old Dec 23, 2014 | 05:31 PM
PriobE's Avatar
PriobE
Has any one figured out the fix for the c1185 code. I have the same issue
josh1095
Aug 28, 2016 09:47 AM
kbangus
Apr 14, 2016 01:42 PM
Nemz
Feb 3, 2016 07:38 PM
cmdavies91
Nov 16, 2015 09:53 AM
flier
Oct 18, 2015 06:18 PM
