Scarebird front disc conversion
Old Mar 21, 2018 | 09:25 AM
Davektm's Avatar
Davektm
Hi Folks and greetings from Bonny Scotland,
ive recently bought a Scarebird conversion for my 72 and I was hoping some of you guys that have done it could provide me with some info?
can I use my standard power brake master cylinder or do I need to change it to a later one and if I do which master cylinder do I need?
i know I need a proportional valve, can you recommend one?
Did you just join your original brake lines down at the original differential valve with a T piece and female x female Union?
Thanks in advance, Davie.
Old Mar 21, 2018 | 06:10 PM
HIO Silver's Avatar
HIO Silver
Greetings from California... land of the fruits and home of the flakes.
Master cylinder... you'll need to swap from a drum/drum MC to a disc/drum MC. Disc brake calipers require more fluid volume to operate properly. Therefore the MC you get will have a large reservoir for the front and comparably smaller reservoir for the rear.
Proportioning valve...i prefer the Wilwood adjustable PN 260-11179
I deleted the distribution valve cuz it is unnecessary when using a proportioning valve.. the prop valve's output is two ports for the front and one port for the rear.
Old Mar 22, 2018 | 12:52 AM
Davektm's Avatar
Davektm
Thanks for the reply, can I use a master cylinder from a later model then? Also I assume I can use the power brake servo I already have and bolt the new MC to it?
Old Mar 26, 2018 | 05:48 PM
JEFFFAFA's Avatar
JEFFFAFA
Yes, you can use a later model Disc/Drum M/C. And your existing brake "booster".
troy676
20
Mar 9, 2013 08:31 AM
talbotmatt
Nov 17, 2006 12:15 PM
65F100project
Aug 24, 2006 05:16 AM
charliehorse
Jan 18, 2006 03:31 PM
mwc4275
Aug 18, 2002 10:17 PM
