Intermittent fuel cooler reservoir puke from vent tube
What would cause intermittent coolant puke from fuel cooler reservoir vent tube? Only seems to happen when i tow my 8000lb travel trailer. I dont drive it hard towing and i keep it at 60mph and keep max boost around 35 when going up grades. Could the fuel cooler pump be going bad? The truck is not throwing out any codes. Is the slight puking normal? Anybody else have this issue? The truck is dpf and cat deleted 4 inch turbo back exhaust with egr coolers blocked off and only running a 70hp tow tune.
also, this system has no recovery...so as the coolant expands and drains out, when it cools there’s no coolant to pull back in....so eventually you wind up with a lot of air.
excessive air lowers the systrm’s Psi and as a result...lots of foaming due to bubbles
this escapes thru the cap drain taking coolant with it
cycle repeats
get a new cap and keep the coolant a the correct level using the eye indicator on the side of the assembly.
Thats why i love this forum!!! Spent hours on the internet trying to find info about the fuel cooler reservoir to no prevail, not much info on it. Thanks speakerfritz this may actually be the problem , looked at the cap and the rubber seal on the cap is toast. I will order a new cap tomorrow and hopefully that solves the problem. One more question is do i only fill half way to sight glass or all the way up to the top? As of now i have been keeping it at half level of the sight glass.
For future reference for people its half way in the sight glass. Going to make it a good practice maintnance issue to look at when im changing the fuel/oil filters on truck to make sure the level is toppped off. Hopefully bringing up this thread with speakerfritz's input will help somebody prevent a fried fuel cooler electric pump.
plgebbia
08-17-2010 11:24 PM
