Flusing Oil Cooler?? Possible??
Old Sep 15, 2010 | 10:20 PM
Heckler's Avatar
Heckler
Ok first let me say that I have no idea what Im talking about but would it be possible to disconnect the coolant lines from the oil cooler (can it be done without major disassembly?) and attach some tubing to the coolant inlet and outlet to an auxiliary pump (maybe a drill pump) to a filter and resivoir with a cleaning agent in it like fleetguard restore and run it for several hours until it breaks down the silicate gel?
Just a thought...
It would be interesting for someone that has a dead cooler that has been opened like the one on the dieselsite to get some of the gel that is found inside the cooler and test to see what is effective to actually break down the gel.
Im just thinking that there has to something out there that can break it down without tearing down half your motor to replace it.. again just a thought.
Old Sep 16, 2010 | 04:32 AM
npccpartsman's Avatar
npccpartsman
The manufacturer says flushing "isn't possible".
Old Sep 16, 2010 | 07:10 AM
DSMMH's Avatar
DSMMH
It cannot be flushed installed. When I put my studs in I removed the oil filter/cooler assemble. I took a hose and connected it to the coolant outlet connection that goes to the EGR cooler and backflushed it. There was plenty of flow coming out of the oil cooler coolant inlet. But about 6 months later I replaced the HX.
If you are not going to replace the cooler coolant HX, you may want to get some radiator cleaner, fill the oil cooler coolant side with it, let it set per the directions and then throughly flush.
DSMMH
Old Sep 16, 2010 | 11:45 AM
Heckler's Avatar
Heckler
I understand that, but the manufacturer also says "use only Ford Gold coolant" which I and many others believe is whats causing the coolers to clog.
If it cant be done it cant be done.. I was just thinking aloud.
Old Sep 16, 2010 | 11:49 AM
Heckler's Avatar
Heckler
Thanks, thats what I was wondering, if it could be done installed (inlet and outlet accessable), I guess if it was that easy someone would have tried that already.
Im just going to do my flush with Fleetguard Restore and VC-9, switch to ELC and hope for the best
DSMMH
