1978 - 1996 Big Bronco
turn signal help plz
Old May 7, 2009 | 12:06 AM
89BroncoHolic's Avatar
89BroncoHolic
I have an 89 bronco xlt! ok where to begin. here are my issues 1.front turn signals dont flash or brighten up and stay on at all 2. hazards work sumtimes(but only the rear flashes not the front) 3.when i turn the right turn signal on it stays on and and the indicator bulb on the dash stays on sumtimes even when the lever is in the off position 4. the left rear turn signal doesnt work at all and all the bulbs are good Im at a loss here and I kept blowing the turn signal AND hazard fuses and the second time after i changed them i no turn signals did anything so i checked for power to the fuses on the block and I had nothing then I checked for power from the light blue wire (which is the power goin to the turn signal switch) that goes to the switch and its good? im so confused lol someone please help Thanks Guys and Gals
Old May 7, 2009 | 12:03 PM
bertha66's Avatar
bertha66
Have you changed out the turn signal switch? I was having turn signal and brake light issuses also on my 80 Bronco, it needed a new switch. Just replaced it last week and all problems went away.
Old May 7, 2009 | 01:23 PM
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
Former Vendor
E7TZ13341B W/TILT
E7TZ13341A W/O TILT
if you do need a turn signal switch maybe I can help you. just visit my site and let me know.
Ed
Old May 7, 2009 | 11:42 PM
Aciancio's Avatar
Aciancio
have you checked the flasher relay
Old Jun 4, 2009 | 05:46 PM
pcar's Avatar
pcar
i have a 95 bronco where all the turn sigals have failed. hazards work fine. Fuse is good where can I find the flasher relay??
Old Jun 5, 2009 | 12:21 AM
greystreak92's Avatar
greystreak92
In the fuse block.
