Power steering lubricant
Old Sep 16, 2003 | 10:56 PM
SCS's Avatar
SCS
Question Power steering lubricant
I am completing the power steering conversion on a 69 using a 77 donor. May be a goofy question, but does the power steering box require any lubricant other than the power steering fluid ? The manual box required hypoid gear oil. If the power box does require this, where do you put it in ? My shop manuals do not refer to any other lube. Thanks in advance.
Steve
Old Sep 17, 2003 | 03:14 AM
willowbilly3's Avatar
willowbilly3
Only the p/s fluid needed. In moderate climates you can get away with tranny fluid but the p/s fluid is more refined and designed to take higher temperatures. If your truck is going to be subjected to subzero temperatures you might want to get some of the stuff from Mercedes Benz that they reccomend for cold weather. It doesn't turn to pudding like the over the counter stuff does at 20 below.
Old Sep 17, 2003 | 10:35 PM
SCS's Avatar
SCS
Thanks for the info.
66v8baby
Feb 24, 2017 07:46 PM
bjd2014
2009 - 2014 F150
Nov 23, 2015 06:00 AM
Caveman2851
Aug 14, 2015 08:38 AM
Lunar Ranger
19
Jan 26, 2012 06:59 AM
twoeyedox
Oil & Lubrication
Feb 15, 2001 03:35 PM
