Speedometer Jumping
Old Mar 19, 2018 | 04:14 PM
twolukes's Avatar
twolukes
Speedometer Jumping
Speedo on my ‘63 F100 started jumping. It makes a clicking noise and jumps up about 20mph. The cable is just a year old and the splines on the drive gear at the transmission end are in good shape. Any suggestions? Will I damage the gauge if I keep driving it until I figure out a fix?
Old Mar 19, 2018 | 05:06 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
When you installed the cable did you lube it with graphite?
Old Mar 19, 2018 | 05:12 PM
resonateur's Avatar
resonateur
...cable lube the cable core, first order of business...
Old Mar 20, 2018 | 10:36 AM
Jeff64F100CrewCab's Avatar
Jeff64F100CrewCab
Is the needle bent a little bit and now rubbing against the glass?
That happened to mine. If so, place some spacers between the front of the speedo and the glass when installing.
I glued some nuts to the speedo face to keep them in position for installation.
Old Mar 20, 2018 | 10:51 AM
daveengelson's Avatar
daveengelson
Sorry, looks like I duplicated the thread>> .
Old Mar 20, 2018 | 10:53 AM
daveengelson
Replaced speedo cable and purchased a tube of the cable lube from popular online Ford part supplier. Found within several months the needle acquired the jitters, I removed the cable, cleaned and lubed using lithium grease; found there are differing opinions on which is best. Anyhow seems the jitters have settled down but I failed to lube the felt washer that sets inside the speedometer inlet housing..
Anyhow, food for thought??
Old Mar 21, 2018 | 04:47 PM
twolukes's Avatar
twolukes
Thanks for the help. Speedo is still jumping. My guess is that the cable is not seating properly at the gauge end. I don’t know if the tiny nut near the end of the cable is supposed to engage or not. I you look at the pick, it looks like something has sheared off, but I’ve never worked back there and the parts manual pictures aren’t very clear. The gauge isn’t burned, that just the graphite.
Old Mar 21, 2018 | 05:02 PM
Jolly Roger Joe
It looks like the end came off the cable and is stuck in the back of the speedo. Or is the end of the cable the same shape as the "hole" it goes into? It looks like the cable end is square and where it fits is round.
Was this a cable kit where you have to cut it to length and smash the end onto it?
Old Mar 21, 2018 | 05:25 PM
daveengelson
Do you recall the part number on the replacement speedometer cable, if so, post the # perhaps member's can offer some suggestions?? I had an issue locating the correct speedometer cable for the 65 with the T-18, it appeared majority of the Ford part supplier's offered a generic cable but not specific for my application. Thanks to the help of members I was able to locate the correct cable.
As mention inspect the end of the speedo cable to determine if portion broke off, also check inside the cable housing.
The end of the speedometer cable end should be correctly aligned when inserted into the speedometer housing and make sure the threaded portion is aligned and hand tightened.
Anyhow, just tossing out food for thought?
Old Apr 18, 2018 | 04:36 PM
twolukes's Avatar
twolukes
Finally - success!
After bench testing the speedo, I bought a new cable from Dennis Carpenter. It came with a metal sleeve and had no kinks or bends. The old one was only a year old, but I couldn't make it work. I pulled the new inner cable and dusted it with graphite, put it back together and after a few misfires it is working nicely. It was important to really tighten the cable onto the back of the speedo. Finger tight leaves about 1/16 of an inch for the inner cable to bounce in and out, which caused the jumping.
Thanks to all for the advice.
Old Apr 18, 2018 | 05:06 PM
daveengelson
Thank you for the update!! Intend pulling the instrument cluster on my 65 w/in the next couple days, I purchase couple items to recondition the instrument gauges to include painting the gauge needles. Appreciate comment/suggestions regarding finger/hand tighten cable to the back of the speedometer, intend making sure connection is relatively tight during reassembly.
thundair
Apr 28, 2015 04:16 PM
rashanny
24
Mar 31, 2011 11:14 PM
ol orange
Aug 14, 2010 12:48 PM
72sportcustom3906.4l
Jun 20, 2009 05:56 AM
matt2491
Mar 14, 2008 02:54 PM
