Squeaky Speedometer
Old Mar 14, 2008 | 12:35 PM
matt2491's Avatar
matt2491
Squeaky Speedometer
After I've been driving around for a little while, I can hear a pretty good squeaking coming from the speedometer gauge. I realize it needs some lube, but do I just pull out the cable it smear it all in there or what?
Old Mar 14, 2008 | 12:55 PM
airharley's Avatar
airharley
I've seen a spray lube but I know there is a grease that coats the cable. Chances are that the noise you are hearing isn't the speedometer but the cable as it enters the cab. Over time the lube breaks down or wears too thin causing the metal cable to squeak.
Old Mar 14, 2008 | 02:54 PM
daveengelson's Avatar
daveengelson
Had simular problem where it sounded like cable was doing one thing and speedo doing another, distinct sound coming from the speedo, lot of noise. Checked and found the retaining connected securing cable to speedo had worked lose. While at it, removed cable and lubricated, not excessive, using what I had left over from greasing the suspension, and drive shaft bearings. There is also a felt washer that sets just inside the speedo housing where the cable inserts. If missing, suggest picking 1 up with next trip to parts store. Use caution, don't think you want to apply too much grease to the washer.
Bryzzle
1997 - 2003 F150
Jan 12, 2018 06:10 AM
Paul Bostic
2004 - 2008 F150
Feb 7, 2017 07:54 PM
Fords & Whalers
WTB - Parts & other
Aug 29, 2016 09:56 PM
redbayredneck
May 11, 2009 07:57 AM
NoMo
Jul 20, 2002 07:40 AM
