question ?
Old Mar 19, 2018 | 09:28 AM
Megathomas's Avatar
Megathomas
Exclamation question ?
Can I use a momentary switch for cranking up a 1995 Ford F-350 with a 351W and if I can, how many amps does the switch need to handle?
Old Mar 19, 2018 | 09:50 AM
subford's Avatar
subford
Are you talking about bypassing the starter relay on the fender or are you asking about powering the starter relay with the switch?
Old Mar 19, 2018 | 11:05 AM
Megathomas's Avatar
Megathomas
[QUOTE=subford;17872018]Are you talking about bypassing the starter relay on the fender or are you asking about powering the starter relay with the switch?[/QUOTE
the smaller bolt to bigger bolt to the starter hook up a switch there the bolt to the starter
Old Mar 19, 2018 | 11:29 AM
jas88's Avatar
jas88
I am still not sure what you are asking. Do you want the momentary switch to supply 12V to the "smaller bolt" as you put it?
Old Mar 19, 2018 | 11:34 AM
subford's Avatar
subford
Very low current push button switch.
https://www.oreillyauto.com/detail/b...ch/s10/2606853
Old Mar 19, 2018 | 12:02 PM
jas88's Avatar
jas88
This is what I use if I am doing exactly as you describe:
https://www.harborfreight.com/12-vol...tch-35448.html
BigRed26
Jan 25, 2019 08:00 PM
GrislteStick
Jul 20, 2017 11:31 PM
sunbelt57
Jun 16, 2015 09:25 AM
meck1
Electrical Systems/Wiring
Apr 5, 2011 06:55 PM
friedslacks
Jul 14, 2002 11:11 AM
