1978 - 1996 Big Bronco
Fuel gauge not working
Old Sep 16, 2003 | 10:17 PM
Hoodlum's Avatar
Hoodlum
Angry Fuel gauge not working
Hey am a new owner of a 87 bronco and the fuel gauge is not working when I turn the truck off it goes down when I turn the truck on it tops out..... Can you folks help me trouble shoot this. It is a 5.0. The bronco runs great. just cant read the fuel gauge.
Old Sep 17, 2003 | 12:15 AM
DW2455's Avatar
DW2455
I just repaired mine, its a 87', i end up making a acsess pannle in the floor (idea stolen from another thread) to get to the gas tank, Trust me its much easier than dropping the tank, but the problem with mine was the float, it's a little thin brass canister that snaps into the float arm, and it had a hole in it. so i cleaned it up with a wire brush, took a butane gas torch and solder, and so far it works. Good Luck with yours! DW
Old Sep 17, 2003 | 09:13 AM
90EBBronco's Avatar
90EBBronco
Had the same problem with my float. $5 (from Ford) and about and hour of work and I had the tank off and the float replaced. Problem fixed. If your sending unit is the problem you are only looking at about $50 to replace that. Those bolts aren't gonna come off easy though. Make sure you have plenty of torque or pneumatic tools. Once you get those bolts off you should be on your way. Needless to say they go back on a lot easier. A test light should help you diagnose your problem. Disconnect the harness at the top of the tank and use a test light to ground the gauge. When grounded it should peg high and if it does, you know that from the harness to the gauge is good. I would bet that your float is cracked though. Good Luck!
KJ
Old Sep 17, 2003 | 01:11 PM
Hoodlum's Avatar
Hoodlum
Thanks all I just bought this beast and I have no idea on troubleshooting it. This bronco was hit on the the driver side fender. Could there be a emergency switch I need to switch?
Old Sep 17, 2003 | 01:22 PM
DW2455's Avatar
DW2455
will it not run? and yes it has a inertia switch, is either inside on the fire wall just left of the break peddle, or behind the pasg. kick pannel. DW
Old Sep 18, 2003 | 10:09 AM
Hoodlum's Avatar
Hoodlum
No it runs great. I just have alot of work to do on it. 100% stock Emission light on, fuel gauge not working, radio is stock, I am fixing everything this weekend thanks folks.
Old Sep 18, 2003 | 03:00 PM
DW2455's Avatar
DW2455
OKay good you ask about the inertia switch so i thought maybe it didnt run, but if it run then your inertia switch is fine. Good Luck. DW
Old Sep 18, 2003 | 07:57 PM
Hoodlum's Avatar
Hoodlum
Hey DW
Do you have pics to that tank conversion. Also the emission light is on and I can't find yhe reset button.
Old Sep 19, 2003 | 09:42 AM
Kemicalburns's Avatar
Kemicalburns
unplug the battery cable and depress the brake for about 15sec that should alow the computer to reset. then hook it back up and go for a drive if possible.
late
Old Sep 19, 2003 | 03:03 PM
Hoodlum's Avatar
Hoodlum
Ok everyone I am taking the beast to the shop to get the gas tank fixed so wish me luck. Thanks for the computer rest. I will try it.
Old Sep 21, 2003 | 01:10 PM
Hoodlum's Avatar
Hoodlum
It was the sending unit. Thanks
Old Sep 21, 2003 | 03:01 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Hey, DW2455
Where is the thread and maybe plans for how to cut that acces panel to get to the sending unit?
Would really like to know.
Old Sep 22, 2003 | 11:09 AM
Kemicalburns
Hey Hoodlum, what did the shop charge you to fix that.
late
Old Nov 7, 2003 | 12:07 PM
Hoodlum's Avatar
Hoodlum
It was around $300.00 but It came with everything intank fuel pump the sending unit.
Old Nov 7, 2003 | 01:00 PM
BillyBob69's Avatar
BillyBob69
Damn not bad for shop time and parts.
greens4x4
Jun 24, 2011 04:25 PM
0351mike
1966 - 1977 Early Broncos
16
Oct 17, 2009 06:06 PM
Johnny Ray
Mar 22, 2009 12:13 AM
FirstBronco
13
Oct 20, 2005 03:57 PM
