Clicking in steering column
Old Dec 19, 2024 | 05:21 PM
WXboy's Avatar
WXboy
I replaced that intermediate shaft on mine a year ago now and the clunking hasn't returned. I hope it never does.
Old Dec 19, 2024 | 05:30 PM
cpobst's Avatar
cpobst
Mine is still good from the dry-lube I used.
Old Dec 20, 2024 | 05:54 AM
Zork's Avatar
Zork
Originally Posted by mjones56
Mine was so tight that lube didn’t help. Replaced it and no more thumping. This absolutely drove me crazy, I also found tie rods nuts, draglink nuts and ball joint nuts basically hand tight. Thank you for the advice.
A bit of a disadvantage to have the 2023/2024 Super Duty trucks forum split out: there's another thread on the newer truck forum:
https://www.ford-trucks.com/forums/1...ing-wheel.html
On the newer trucks, FORD will apparently replace the section shaft under warranty!!! Not sure why they don't for the older trucks, if the problem is the same?
msgtord
2015 - 2020 F150
Oct 19, 2016 06:40 PM
bigblue80
2004 - 2008 F150
Jan 4, 2006 07:19 PM
Saguaro_7.3
Nov 7, 2005 10:52 PM
Garycas
2004 - 2008 F150
Sep 13, 2004 01:57 PM
