Sponsored by: Real Truck
Fuel issues?
Old Mar 16, 2018 | 02:00 AM
TrishW's Avatar
TrishW
Fuel issues?
Ok so I recently bought my fathers used 2011 f250 6.2 L V8.
Gas gauge went out about 6 months ago. It was his back up truck so he just clocked mileage. When you first turn key it shoots to full then drops to empty immediately.
However it sat for a few months, now that I have it; I changed the oil and did a tune up. Checked all fuel related fuses.
Now; day one full day driving no issues. Few days later I go to fill up and the gas pump keeps shutting off after just a few gallons. I know it’s near empty.
So today it cranks but won’t turn over.
Im assuming it’s all related to fuel somehow but where do I start?
Old Mar 16, 2018 | 03:54 AM
Chuck's First Ford's Avatar
Chuck's First Ford
the fuel pump shutting off.. is the 6.2L fuel tank vent.... its clogged up. spider nest.. or bug nest..
as for cranks but won't turn over..
do you MEAN.. it turns over (cranks) but will NOT FIRE up... and run..??? ( weak battery )... dirty battery connections.. or cable ground problems.
Old Mar 16, 2018 | 08:00 AM
TrishW's Avatar
TrishW
Yes that exactly. Tries to turn on but won’t. However I let it cool off all night and it started right up today.
So the vent vent even though it will run 100’s or miles once it’s on? Makes sense I was thinking sending unit since the gas gauge is out but the pump is obviously working.
Old Mar 16, 2018 | 08:32 AM
TrishW's Avatar
TrishW
Fuel vent*
hundreds of miles*
Any other typos I missed I apologize y’all.
Old Mar 16, 2018 | 09:16 AM
Chuck's First Ford
Originally Posted by TrishW
Fuel vent*
hundreds of miles*
trust me.. I can NEVER be the spelling police...
Old Mar 16, 2018 | 09:27 AM
scott sargent's Avatar
scott sargent
key less remote quit working on my 2002 super duty. Ive changed the battery and still no responce
Old Mar 16, 2018 | 02:39 PM
DogRidesInBack's Avatar
DogRidesInBack
Fuel vent*
hundreds of miles*
No problem. Please note there is an edit button for your post, you can fix the typos for about a month IIRC. I do it all the time with my posts.
And yes, make sure the electrical system (batteries, big cables, and grounds) are good. There are other things that could cause your problem, but always good to start with these basic items.
And welcome to FTE!
I can, but generally don't unless the fail is egregious. Then I have to say something. It is not just spelling, either. I still try to be nice when doing it.
Welcome to FTE to you too!
Please start a new thread rather than jumping into an unrelated problem.
Old Mar 18, 2018 | 07:56 PM
TrishW's Avatar
TrishW
It’s fixed!
Well 500.00 later it’s fixed. Fuel pump AND clogged line to that back canister.
Dropped the tank and the fuel pump and sending unit were both fried. Also had a small crack in a fuel line.
Magically replacing the fuel line and the pump; as well as cleaning that vent tube it’s all working again. Thank y’all so much. It’s greatly appreciated!
Jmerchant6_9
Sep 12, 2018 07:41 PM
MoBill122
Aug 23, 2017 05:02 PM
Orpackrat
1983 - 2012 Ranger & B-Series
Dec 27, 2009 08:23 PM
MadCowRacer
2004 - 2008 F150
Mar 23, 2009 12:00 PM
