Need some brake help!
Old Mar 14, 2018 | 03:52 PM
orlando.ortiz3's Avatar
orlando.ortiz3
Hey guys,
Need some help. Recently acquired an 82 F-250 4x4 XLT, and realized that neither the turn signals or brake lights were working, running lights were fine. Checked grounds - looked good, changed all bulbs, when I realized the turn signals weren't working due to the hazard light **** on the steering column being pulled out. With the turn signals out of the way, what else can I do to narrow down the issue(s) with the brake lights?
Old Mar 14, 2018 | 05:23 PM
Franklin2's Avatar
Franklin2
So now everything works except the brake lights? First thing to do is get a testlight and check the switch on the brake pedal arm underneath the dash.
Old Mar 14, 2018 | 09:35 PM
orlando.ortiz3
Correct every is working except for brake lights, and hazards, which apparently never worked, but not too concerned about those now. Don’t have a test light, but took a multimeter to the brake pedal switch and got 12v. Couldn’t get 12v at either of the bottom 2 sockets at the tail light... is it just coincidence that both bottom sockets/wiring went bad, while both of the top ones are fine? They are wired individually correct?
Old Mar 15, 2018 | 09:50 AM
FuzzFace2's Avatar
FuzzFace2
So you have 12 volts on both sides of the brake light switch when the pedal is pushed?
If so I would say the turn signal switch is bad.
Power goes from brake light switch to turn signal switch so if you have the signal on 1 side and pressed on the brake the turn over rides the brake light.
The 4 way is also part of the turn signal switch.
Dave - - - -
Old Mar 15, 2018 | 10:28 AM
orlando.ortiz3
The turn signal switch is in the steering column correct?
Old Mar 15, 2018 | 12:27 PM
FuzzFace2's Avatar
FuzzFace2
Yes at the top, you have to pull the steering wheel off to get to it. There is a puller needed for the wheel removal.
The wires run down inside the colum to a plug at the bottom.
take note of the wire colors in the plug as the wires need to be removed from the plug. A paper clip may work to get them out.
Tie string to the wires at the plug end and pull them out thru the top. Tie string onto the new switch wires and pull them back down using the string.
The rest is backward of how you got it out.
Dave - - -
TexanAmmo
22
Jul 22, 2018 02:31 PM
rezdawg
Oct 9, 2012 12:05 PM
my774x4f250
Sep 13, 2008 05:52 PM
Galizien
Oct 3, 2006 03:29 PM
workingdog
30
Jun 15, 2006 09:01 AM
