2018 or 2019? Should I wait?
Old Apr 16, 2018 | 05:43 PM
  #31
PremierPOWER's Avatar
PremierPOWER
Anyone know if it will be possible to update 2018’s with the new ford pass? Would love to be able to remote start from phone.
Also curious how much beter the new stereo stereo will be compared to the Sony.
Old Apr 16, 2018 | 06:48 PM
  #32
350ute's Avatar
350ute
I ordered an F350 6.2, XLT SRW, regular cab 4x4 on April 3rd, told me 6-8 weeks. Had been going back and forth with the diesel, always wanted one, but finally settled on the gas. My dealer who is a smaller one, told me I got one of the last two Superduty's they were allocated to. He said the build date is May 14th, so hoping to see it by first part of June.
Old Apr 16, 2018 | 10:47 PM
  #33
SDTruckMan's Avatar
SDTruckMan
When is the cutoff for ordering a 18? Dealers are all over some say they cant order some say the 19th of April. Is it dependent on if they have allocation?
Old Apr 16, 2018 | 11:59 PM
  #34
supeRobertduty's Avatar
supeRobertduty
Wait just a little longer and go for the redesign in 2019 cy. The 2020 model will be spectacular.
Old Apr 17, 2018 | 09:16 AM
  #35
SDTruckMan's Avatar
SDTruckMan
When is the 2020 expected to be out for ordering since they are doing 19s now.?
Not sure I want the first model year of a new engine / redesign.
Old Apr 17, 2018 | 09:49 AM
  #36
h20camper's Avatar
h20camper
I'd GUESS March/April of 2019. My understanding is they are trying to get back to regular schedule.
Old Apr 18, 2018 | 09:36 AM
  #37
BronzefireAL13SD's Avatar
BronzefireAL13SD
Originally Posted by WesC.
SDTruckMan;
Ordered the 4.30 Electronic Locking because I plan on towing a 5th Wheel. (Aprox 10,000 lbs.)
The reasons I'm ditching the Diesel and going gasser are many. I'll try to list a few.
Above all else, I hate the Diesel because I don't understand it. This is of course my lack of knowledge, not anything negative on the truck. I understand a gas engine. I've worked on them, and can work on them. That being said, the other reasons are as follows:
If I run out of DEF fluid, the truck will go into Idle only mode. So, a $65,000 truck will basically shut down because All Gore says it should. To me this is government overreach at its worst. True, if I don't put fuel or oil in the truck it will also shut down, but the principle of big brother telling me I have to essentially let Al Gore pee in my truck in order for it to run is too much to bear. (DEF = 60% water, 40% Urea) DEF is also expensive, and an extra caveat of owning a Diesel and there are many.
When we first picked it up, we said, "Wow, for a Diesel it's really quiet." No so much a year and a half later. I was however warned that with age, the diesel will get more noisy, but I did not think it would happen this soon.
Every other oil change is $300 because you have to also change the two, yes two, fuel filters because diesel engines are very sensitive to contaminants in fuel, especially water. Which leads me to...
You have to drain the water/fuel separator once a month for two reasons. One, to get the water out if present, and two to determine if the gas station you are using is quality.
Maintenance costs are prohibitive if out of warranty. Three years and or 100,000 miles (Drivetrain) is just when the EGR cooler or fuel pump fails, or injectors got enough water from a bad tank at an obscure station that you had to stop at, that the cab of the truck has to come off to service it. (Slight exaggeration, but only slight.)
Fuel gelling.
Cold starting. The block heater does little, and you have to estimate when you are going to use the truck to schedule when you are going to plug it in, or use a timer. What?
Turbo lag.
Turbo still has the ceramic bearings flaw. Why Ford did not fix this is astonishing. So yea, you're gonna need one of those just when its out of warranty.
Diesel fuel costs more. I've heard that a diesel gets better fuel mileage. The research, (Others posts, various blogs) shows the difference is between 14.7 mpg city and 14 mpg city. (Again, exaggeration, but really really close) What am I to do with all that extra fuel money i'm saving on .7 mpg?
Lastly and most important, the diesel option, factoring in taxes, is a $10,000 upgrade. (aprox.) You can check a hell of a lot of boxes for ten grand. And when I ordered my 2018 Gas Lariat, I checked almost every single one. Giving up the diesel gets me options I have no business being entitled to. As a daily driver, yes I want seven cameras and a heated steering wheel with a moonroof the size of my first apartment.
I've heard the warnings. If you are going to pull anything bigger than a pop-up trailer, you need a diesel or the earth will literally stop spinning.
When I'm towing my 5th wheel over the Himalayan Mountains, yes I'm gonna say, "I wish I had the diesel."
...but until then, I'm going with what I understand. Gas.
I hope anyone who reads this understands it's satire. Please, no fact checking. I embellished here and there to make a point and to get a chuckle. I hope I did both.
I'm told ordering 2018's ends at the end of this month (March).
Good luck with your order, and your new truck.
Life is short, have fun and drive whatever ya like.
Wes
I've been a gas truck owner diesel mechanic since 1986 and I couldn't have said it better.
with that said I just bought my 1st diesel. Why? Because that's what all the cool kids are driving.
Old Apr 18, 2018 | 11:21 PM
  #38
SDTruckMan's Avatar
SDTruckMan
What can we expect for rebates when the 19s hit the lots. Will they keep the 1000 rebate intact or do away with it for a while.
Old Apr 27, 2018 | 06:16 PM
  #39
WesC.'s Avatar
WesC.
Ordered 3/14
Window Sticker 4/4
Built 4/11
Delivered 4/26
2018 F350 Gas, Lariat Crew Cab, 8' Bed, Spray in bed liner.
mxer0022
6.7L Power Stroke Diesel
Jul 11, 2019 04:01 PM
ExpyAZ
Aug 31, 2015 09:11 AM
judithgap
6.2L V8
Jan 9, 2013 08:49 PM
ColdH2O
923
Dec 20, 2010 02:29 AM
///M Puller
May 13, 2008 12:19 PM
