Prop Valve Location Question?
Old Mar 26, 2018 | 07:07 AM
  #31
ultraranger's Avatar
ultraranger
Originally Posted by Thipdar
So they have completely eliminated the safety warning system that indicates loss of brake pressure? No "Dual Brake Warning Lamp" capability AT ALL?
Nope. The lines for the front brakes and the rear brakes are segregated through the Wilwood valve body. The only function (other than the ability to trigger the brake lights) is a proportioning function.
Old Mar 26, 2018 | 01:37 PM
  #32
Davektm's Avatar
Davektm
Hey guys,
im doing a front disc conversion on my 72 F100 that already has power brakes, can I put the explorer master cylinder that Ultraranger suggests onto my current brake booster?
Old Mar 27, 2018 | 07:25 AM
  #33
xanthias's Avatar
xanthias
UltraRanger’s information is excellent as always. I offer this reply only as another option. I’ve had good luck with this particular vendor on eBay. They sell bolt-on setups for our trucks and you can get a booster/master cylinder/proportioning valve combination. The brake pedal rod is adjustable. Here’s an example for your ‘69:
https://rover.ebay.com/rover/0/0/0?m...2F331982704800
all you need to do then are the peripheral lines.
Old Mar 28, 2018 | 01:30 PM
  #34
Davektm's Avatar
Davektm
Ive ordered a 95 explorer mc from the US based on ultraranger's mod, will see how it works out with the Scarebird conversion
Old Mar 28, 2018 | 09:34 PM
  #35
ultraranger
Originally Posted by Davektm
Hey guys,
What brake booster do you have? (seeing a photo posted of it would be even better).
Old Mar 31, 2018 | 06:31 AM
  #36
F100-1969's Avatar
F100-1969
Yall are outstanding, thank you for all of the great information.
Old Mar 31, 2018 | 09:55 AM
  #37
Davektm's Avatar
Davektm
Its the the original booster from the 72 power drum brakes which looks very similar to yours, I don't have any pics handy I'm afraid.
Old Mar 31, 2018 | 10:25 AM
  #38
ultraranger
I assume then that this is a single diaphragm booster? Generally, with a MC bore over 1.00" diameter, it's best to have a dual diaphragm booster. The '95 Explorer MC has a bore diameter of 1.062" (1-1/16"). However, a dual diaphragm booster on a truck with (self-energizing) all-wheel drum brakes would probably make the brakes very sensitive to the application of the brake pedal.
To get the most potential and best function from the brakes, the proven recipe for this is: front disc brakes, dual diaphragm brake booster and a 1-1/16" bore MC.
David LaPell
Jun 10, 2016 12:26 AM
Baer
May 18, 2016 08:06 AM
jwal1
Aug 2, 2012 06:38 PM
FLN
Jun 1, 2008 09:56 AM
TremecGT
May 17, 2005 03:49 AM
