disc brake conversion brake lines
Old May 31, 2008 | 07:20 AM
FLN's Avatar
FLN
im converting over to disc brakes on my 68.im at the brake line part.can the original steel lines be used or are disc brake lines a different diameter?i have the proport. valve and was going to tie into old lines with couplers.can anyone give me a start to get going?
Old May 31, 2008 | 07:52 AM
jwtimme's Avatar
jwtimme
the orriginal hard lines can be used, but you will need to buy diffrent rubber lines to fit the calipers, I just bought lines for a 79 ford truck from a local auto parts store. I have a 72 but I did not need to add any line to get the prop. valve to fit.
Old May 31, 2008 | 04:28 PM
jowilker's Avatar
jowilker
All needed parts come with donor purchase.
John
Old May 31, 2008 | 04:49 PM
FLN's Avatar
FLN
brake hose
i purchased new hoses & calipers but hose is too short for stock location .are hoses longer for later years?this is a 74 model going to a 68.
Old May 31, 2008 | 07:08 PM
DarkWolf40's Avatar
DarkWolf40
You need the brakets to mount on the frame. the hard lines go under the frame and mount to the brackets, then the flex line goes from there. If you didn't get the hard lines from the donor, you should look for some from a junkyard because the piece that goes under the frame has a kind of a convoluted covering to protect it from rocks and such.
Old Jun 1, 2008 | 05:42 AM
jowilker's Avatar
jowilker
Purchase your donor, and all parts come in the kit.
Damn straight I am trying to drive my point home.
Buy, purchase, pay money for a complete donor and E V E R Y T H I N G is there,
including the visual on how to build it back.
John
Old Jun 1, 2008 | 09:56 AM
jwtimme's Avatar
jwtimme
some people don't have the room or the city will not let them park a donor truck around their house, yes a donor will give you all the parts but a junk yard can be cheaper in the long run.
