Bad Freeze Plugs
Old Mar 11, 2018 | 02:09 PM
irvdog63's Avatar
irvdog63
Bad Freeze Plugs
Good Day, I have a 1985 Ford F250 HD with a 7.5l XLT Lariat. My issue is the block plugs (freeze plugs) are leaking on each side. Has anyone had any luck replacing them while the motor is in the engine? I believe that there is a plug behind the motor mount on each side. It appears that there is very little room to replace squarely with the engine still in the motor. I don't like the rubber seals, I guess I am just old school. Any help is certainly appreciated. Thanks, RJ
Old Mar 11, 2018 | 05:39 PM
FuzzFace2's Avatar
FuzzFace2
Pull the motor and do them right.
I have a factory v8 in a small body car that a plug started leaking on.
Till I could pull the motor to replace it with the rubber type I . Shortly after I had another start leaking, rubber plug again and another leaked. Even had 1 in a head leak.
All the rubber plugs were so I could move the car till I had time for a good repair. The time has not come yet and it has been close to 10 years now and the car sits in my garage.
Again pull the motor and replace them all and enjoy the truck.
Dave ----
Old Mar 11, 2018 | 07:08 PM
Franklin2's Avatar
Franklin2
I had to pull the engine in my ranger and replace them. Someone never changed the anti-freeze in it, just kept adding water. It was full of rust sludge, the radiator would not even drain. I finally got it all cleaned out, and that is when the freeze plugs started leaking, one on each side. I tried the rubber expanding plugs, but one of them kept popping out. I barely got those type in place. I finally pulled the engine and glad I did, this 2.9 v6 has a freeze plug behind the bellhousing and it was seeping. You can't change that one without pulling the engine. I have since found out the 6.9/7.3 idi diesels also have a freeze plug in behind the bellhousing area also. Don't know if the 460 does or not.
Old Mar 12, 2018 | 07:25 AM
reamer's Avatar
reamer
Put them in "time out" until they act correctly.......
Really, pull the engine
Old Mar 12, 2018 | 06:16 PM
matthewq4b's Avatar
matthewq4b
If you got one or 2 and can sort of get at it and do not feel like pulling the motor just replace it with a block heater. Those as a rule do not ever leak.
Old Mar 13, 2018 | 10:31 AM
Franklin2's Avatar
Franklin2
The problem I had with the 2.9 v6, there was not enough depth in the water jacket to get the rubber plug far enough into the freeze plug hole. The 460 may have a deeper water jacket and it would work better. If you desperately need the truck, you could try them and see if they work for you.
Old Mar 14, 2018 | 03:55 PM
cadunkle's Avatar
cadunkle
I've had one leak, then some time after replacing the old hardened o-ring it fell out going down the highway. It was a long run to a nearby NAPA to to get there for a rubber plug before they closed.
Old Mar 14, 2018 | 06:51 PM
matthewq4b's Avatar
matthewq4b
Not exactly sure how it could fall out as they are captured in place with a butterfly on the back. And a leaking block heater is pretty rare beast. I have far fewer leaking block heaters than freeze plugs. Think I had one that leaked.
Old Mar 20, 2018 | 02:34 AM
NZCOBRA's Avatar
NZCOBRA
A good tempory fix . " Seal Tabs " you put them in your top hose whole and they only block the leak where there is oxygen , my freeze plug was leaking badly drip drip and it easily fixed it , changed them about a year later . Took motor out .fitted brass ones !
Old Mar 20, 2018 | 06:17 AM
cadunkle's Avatar
cadunkle
The retaining bar on the backside had cracked, judging from the part of it I found.
Old Mar 20, 2018 | 11:58 AM
matthewq4b's Avatar
matthewq4b
Always a risk when you reuse block heaters as they are technically an install one use.
irvdog63
Apr 6, 2018 09:02 PM
first today
Oct 10, 2010 06:57 AM
lucky_strike
29
Oct 7, 2010 10:09 AM
Bobtailfan
1966 - 1977 Early Broncos
May 14, 2006 10:41 PM
nissanjon
Dec 17, 1999 03:58 PM
