1992 E150 clock spring ?
Old Mar 8, 2018 | 11:39 PM
gman97005's Avatar
gman97005
I have looked everywhere including Dorman and can't find a replacement and it's probably because of the steering wheel mounted controls for cruise control, does anyone have a lead on a new not used clock spring ?
Old Mar 9, 2018 | 12:39 AM
annaleigh's Avatar
annaleigh
You wouldn't happen to know the part number would you?
I do not know if this one is with cruise or not.
Ok looking at this site (and I don't know if it is accurate) You might want to ask NumberDummy to verify the part number.
https://www.fordpartsgiant.com/parts/ford-contact-ring-and-brush-assy_f4uz-13806-b.html?Make=Ford&Model=E-150&Year=1992&Submodel=&Filter=(e=8-cyl-5-0l;t=4at-aod)
Says F4UZ-13806-B fitsF4UZ-13806-BBase No.13806Part DescriptionContact Ring And Brush Assy
10-pin connector mates to 14401, #9C899 is 3-pin spring loaded mating to 3-ring brass contact of #3600, w/o air bag, w/speed control
Actually the Ford Partrs Giant list says they have it on one page for $95 while it says discontinued part on another page.
They also say part number F2UZ-13806-B Replaced by:F4UZ-13806-B
Here is one on Ebay
NEW OEM Ford Steering Wheel Clock Spring F4UZ-13806-B E150 E250 Econoline 92-96
https://www.ebay.com/itm/NEW-OEM-Ford-Steering-Wheel-Clock-Spring-F4UZ-13806-B-E150-E250-Econoline-92-96/152575655806?epid=1122232809&hash=item238637bf7e:g :OMQAAOSwerxanWGj:sc:FedExHomeDelivery!30144!US!-1&vxp=mtr
Old Mar 9, 2018 | 12:58 AM
gman97005's Avatar
gman97005
thank you, i just bought two of them for $125 each..
Old Mar 9, 2018 | 01:19 AM
annaleigh's Avatar
annaleigh
Welcome,,, Yours does not have air bags correct? Because it says without air bag
Old Mar 9, 2018 | 01:21 AM
gman97005's Avatar
gman97005
it has 3 connectors, 1 for the horn, 1 for the airbag and 1 for the cruise control which has 6 wires in the connector, on-off-set-resume-coast and ground..
Old Mar 9, 2018 | 01:31 AM
gman97005's Avatar
gman97005
It does but i don't care if it works or not, i just needed the horn and cruise control..
Old Mar 9, 2018 | 01:47 AM
annaleigh's Avatar
annaleigh
I hope it works.. something must have changed in 93 and be glad you dont need that one... $340.00
https://www.ebay.com/p/Ford-E-Series....c100005.m1851
zarmo
Sep 16, 2016 08:33 AM
kelwar
Mar 30, 2009 11:21 PM
DieselBeast01
Aug 11, 2008 10:24 AM
tomdoggie
2004 - 2008 F150
Nov 23, 2004 11:12 AM
Bolliger
May 19, 2004 10:49 PM
