6.7 powerstroke knocking soind
Old Mar 8, 2018 | 10:31 PM
Chris Steigelman's Avatar
Chris Steigelman
just got back from a 16 hour trip picking up a boat, truck performed fine for the entire trip. Once back, I left the truck idling in the road for 15-20 minutes while I cleared space in the driveway and went I went back to the truck it had a very loud, obvious knocking sound. The sound was not there at all when I got out of the truck...I would have noticed it, it’s LOUD. The sound changes in severity with engine RPM’s. No recent oil changes, Currently at 7,000 miles since last change with rotella T-6. I test oil regularly on 5,000 mile intervals with no evidence of excessive metal content in oil. Any ideas what it could be? Don’t think it’s a rod or valve knock bc of how quickly it started...clogged injector, EGR valve issue? I was getting about 6.5 mpg with the boat hooked up, so I didn’t miss many gas stations along the trip, one station had very slow pumps like maybe the pump filters were clogged?? ...bad fuel?
I’m really hoping it’s not a major engine failure, any advice is appreciated.
Old Mar 9, 2018 | 08:08 AM
rob17's Avatar
rob17
That doesn't sound right at all. I tow a 15K pound fifth-wheel and have never had fuel mileage that low.
Rob
Old Mar 9, 2018 | 02:03 PM
cangim's Avatar
cangim
How big, wind load, and heavy is this boat? I agree 6.5 sounds off, unless it is some small yacht the size of a barn. Can you capture video of the sound?
Old Mar 9, 2018 | 10:24 PM
FishOnOne's Avatar
FishOnOne
A bad injector can cause a loud tapping noise
Old Mar 12, 2018 | 08:00 AM
Chris Steigelman
Changed oil to see if anything was in the pan...nothing. Also put some fuel treatment in with a fresh tank of diesel. Knocking got significantly quieter...assumed it was a clogged injector that was clearing up. Was on my way to local diesel shop to have them check it out still when i got one very LOUD knock and the engine started running rough and lost most of the power...then before I could find a place to pull over and shut her down...the motor locked up.
It’s a 2012, 125k miles so no warranty. She currently sits at the Ford diesel shop and I’m awaiting inspection...any common factory issues that could lead me to get some post-warranty help from Ford?
any words of wisdom?
Old Mar 12, 2018 | 07:47 PM
dirthawg's Avatar
dirthawg
There has been a few reports of spun main bearings on the early 6.7's.
FFW to 12:30
Old Mar 13, 2018 | 08:20 PM
willydmax's Avatar
willydmax
Let us know what the outcome is. Curious what they will find.
xaviar
Jan 28, 2020 12:45 PM
2009kr
6.7L Power Stroke Diesel
May 27, 2019 07:50 AM
2010F350
6.4L Power Stroke Diesel
Nov 13, 2015 11:52 AM
460k&n
Modular V8 (4.6L, 5.4L)
Apr 22, 2010 10:34 PM
GopelT
Jan 4, 2004 07:42 PM
