Recall: FSA 17M04 - Ford Truck Enthusiasts Forums
Recall: FSA 17M04
Old 12-18-2017, 09:14 AM
F250_Super_4X4's Avatar
F250_Super_4X4
F250_Super_4X4 is offline
F250_Super_4X4 is gaining momentum as a positive member of FTE.F250_Super_4X4 is gaining momentum as a positive member of FTE.
Recall: FSA 17M04
Just received a note from my dealership of a possible recall on the Crankcase Ventilation Oil Separator Assembly. My truck is a 2015 PSD KR
Old 12-18-2017, 12:22 PM
Just Strokin
Just Strokin is offline
Just Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud ofJust Strokin has much to be proud of
A FSA (field service action) is not a recall.
Goggling FSA 17M04 shows it to be a warranty extension to 120,000 from warranty start date. Some say your letter/notification from Ford may not arrive til February.
If you log into Ford Owner, it gives you similar info as probably your dealer supplied you. It is showing up on my 2015 F350 on the website. FordPass should show similar.
There might be a possibility of getting a refund from Ford if the CCV has been replaced or repaired previously.
Old 01-10-2018, 08:44 PM
F350-6's Avatar
F350-6
F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
This just showed up on my vehicle health report.
Does anyone know what the supposed weak point / failure mode of the CCV is that they are concerned about?
If it's somehow falling apart and ingesting dirt into the engine, I'd rather find out sooner than later. If a little crank case gas is venting a hair too much, I'm not quite as concerned.
Old 01-10-2018, 09:15 PM
Just Strokin
Chris
Do a search of this forum for CCV and crankcase ventilater, and other similar terms. I think there have been some threads about it.
Old 01-10-2018, 09:21 PM
F350-6's Avatar
F350-6
F350-6 is offline
I tried when I got the notice. This forums search function and me don't get along too well. I found this thread by searching google for the FSA number. Searching the 6.7 section on FTE with the same words got me nothing.
Old 01-10-2018, 10:09 PM
HRTKD's Avatar
HRTKD
HRTKD is offline
HRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant future
Chris, a more effective way of searching the FTE site is to enter something like this in Google:
FSA 17M04 site:www.ford-trucks.com
The key is to add the "site:" part. Unfortunately, you can't filter down to just one of the forums with that search method. The advanced search on this site will let you filter down to a single (or multiple) forum.
Old 01-10-2018, 11:07 PM
Just Strokin
Chris,
Here is one thread from searching for "Crankcase". Appears it will throw a code P04DB. You might search for that code.
https://www.ford-trucks.com/forums/1...case-vent.html
Here is the section from the MY2015 OBD System Operation
https://www.motorcraftservice.com/freeresources/obd
The 6.7L diesel engine has a crankcase ventilation separator mounted on the driver side rocker cover, with a
tube connecting the separator to the fresh air inlet of the turbocharger. The tube on the separator side has a
tamper proof collar installed and is plastic welded to the separator. On the fresh air inlet side, a hall effect sensor
is present, to detect connection to the inlet casting assembly. The tube cannot be disconnected on the separator
side, and if it is disconnected from the inlet casting, a P04DB code is set, as sensor output drops below a
calibrated threshold. There are also circuit range checks, P04E2 and P04E3 to detect shorts to ground, or short
to battery/disconnected sensor, respectively.
Crankcase Ventilation Monitor
DTCs P04DB – Crankcase Ventilation System Disconnected
P04E2 – Crankcase Ventilation Hose Connection Sensor Circuit Low
P04E3 – Crankcase Ventilation Hose Connection Sensor Circuit High
Monitor Execution Once per driving cycle – P04DB
Continuous – P04E2, P04E3
Monitor Sequence None
Sensors OK P04DB - CVM (P04E2, P04E3)
Typical Monitoring Duration 2 sec
Old 01-11-2018, 09:14 AM
F250_Super_4X4
So scuttlebutt I have heard is that the filter/separator is clogging causing excessive crankcase pressure. The new system you can replace the filter (>2017). I'm waiting on a retro fit solution that I assume Ford is working on.
Old 01-11-2018, 07:39 PM
F350-6's Avatar
F350-6
F350-6 is offline
Thanks Larry. That makes me feel a bit better. As long as the code is tripped if unfiltered air is entering the intake, I do fee better.
I wonder if the warranty will cover the resulting oil leaks if that is indeed what's going on?
Old 03-13-2018, 12:53 PM
mark63368
mark63368 is offline
mark63368 is starting off with a positive reputation.
P04DB Code
My 2015 F350 threw this code, P04DB, the other day. I called the Service Manager at the dealer and he pulled up the service bulletin and said that it takes 7/10th of an hour according to the book and that it's completely covered. I've got an appointment today so I'll talk to the tech and see what is actually causing it and what the "repair" actually entails.
This also causes the remote start not to function. It cleared itself after a few miles then came back on. I believe the data logger will clear itself after a few warmup cycles without it throwing the code so make sure you call or take it in when it happens.
I never received any notification from Ford.
Old 03-13-2018, 01:10 PM
F250_Super_4X4
Hopefully they are able to retrofit a 17 MY version but most likely will just replace it because its part of the lifetime warranty under emissions.
Old 03-13-2018, 02:46 PM
bkuuz1
bkuuz1 is offline
bkuuz1 is gaining momentum as a positive member of FTE.bkuuz1 is gaining momentum as a positive member of FTE.
Not sure if when the dealer replaced mine, just after 35K, if it was a new style or not but as of yet I have not had any issues with it.
When mine was throwing the code it was only a connection issue and nothing else.
Old 03-14-2018, 08:15 AM
Painted Horse's Avatar
Painted Horse
Painted Horse is offline
Painted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant future
I had forgotten about this. My 2015 had this and I took it in for replacement. Now I need to check and see if I paid for it or if warranty covered it.
Bohen
6.7L Power Stroke Diesel
01-09-2018 05:58 AM
kcwolf200
2017+ Super Duty
15
06-24-2017 09:41 PM
PwerStroke99
2017+ Super Duty
24
03-15-2017 05:40 PM
EightySecond
2017+ Super Duty
03-15-2017 08:59 AM
kper05
37
04-22-2012 04:10 PM
Quick Reply: Recall: FSA 17M04
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
