Sponsored by: Real Truck
ABS Pump Parts
Old Mar 8, 2018 | 06:46 PM
dgreen1069's Avatar
dgreen1069
ABS Pump Parts
I just replaced the brake lines on my 2003 Excursion. The line for the driver's side front brake is leaking at the ABS pump and I'm certain the fitting on the pump got messed up during the repair. I don't particularly want to replace the ABS pump, and I'm not sure I have to. The pump outlets where the brake lines attach to the pump appear replaceable. Once you remove the brake lines from the pumps, the actual seats for the lines can be removed. Does anyone know if this is a part that Ford stocks? I can't seem to find a diagram for the pump or any part numbers for replacement parts.
Remmons
Mar 20, 2018 07:23 PM
MadMatt65
1978 - 1996 Big Bronco
Oct 19, 2017 07:47 PM
Rivera1114
Feb 13, 2011 08:39 AM
truckboy23
Jul 22, 2010 12:49 AM
