'99 4r100 Trans question
Ok, so I've recently aquired this 99 F-250 6.8l. This is our sole daily driver and will need to tow our travel trailer to the Tennessee mountains as we trek to Florida and back every year.
I've noticed that occasionally I get the wiff of burnt transmission fluid smell. Doesn't seem to be any rhyme or reason as to when it happens. Torque converter stall seems solid at 1200 RPM consistantly, which I would also think might also speak for first gear. It feels good/solid shifting into reverse or drive and appears to shift nice and smooth. Not sure if it's a second or third gear issue, does not feel like it slips at any point in time. I have not had a load of any type on it yet. Seems to happen with overdrive on or off. There's a mechanical temp guage that tops out around 120° warm. I believe it is in-line with the outgoing cooler line.
The fluid does have a slight aroma of burnt to it. There is an inline trans filter of unknown age/origin that I intend to change as well as fluid flush and I intend to refill with Mercon V.
My question is, any thoughts on a cause? And, is this trans cooked because the occasional burnt smell? Am I just throwing money away swapping fluid/filter (on a really tight budget)? Ideas?
Thanks in advance,
Lorne
Last edited by lhutter1; Mar 8, 2018 at 08:33 AM. Reason: A few word tweaks to better describe.
Are there any leaks? Any wet spots on the transmission, cooling lines, or transmission cooler?
120°F is a very, very low temperature for the outgoing cooler line. I'd expect a reading that low on the line returning from the cooler. A much better place to measure transmission temperature is in the test port on the driver's side of the transmission.
A slight burnt smell does not prove the trans is done. It does mean the fluid needs to be changed. Here is how I do it: Changing ATF.
Earlier it was asked if I have any leaks and the answer is no, there are no leaks of any kind.
