Sponsored by: Real Truck
Plugged Trans Cooler?
Old Jul 30, 2013 | 07:20 PM
splice1985's Avatar
splice1985
Well, today was an adventure. I decided to go change the ATF fluid in my 4R100 (early 99 F350 7.3 4wd) following the instructions found here:
https://www.ford-trucks.com/forums/1...and-video.html
However, my trip took a turn about halfway through. I got the pan drained, dropped, filter replaced, crud cleaned out of the bottom, and pan reinstalled with no issues. Then, I pulled the trans cooler return line.
Reference blue and red arrows. Red arrow was where I expected the trans fluid to flow out of when I started the truck... blue arrow was Ole' Bessie on a flat rock 6-9 seconds after startup.
When I pulled the return line initially, fluid was running in a light stream from the blue arrow and never stopped until I plugged it back in.
Needless to say, the auto hobby shop personnel weren't pleased and I got to wipe the floor for the next half hour.
End result is: new filter, and 12 qts of fluid changed. I suspect the trans cooler is plugged (no temp gauge) which is why the fluid came out of the aft port on the trans instead of the return line. Anybody dealt with this before?
Old Jul 30, 2013 | 11:04 PM
DND58's Avatar
DND58
This thread may help.
https://www.ford-trucks.com/forums/1...l#post13380163
Old Jul 31, 2013 | 03:19 AM
splice1985's Avatar
splice1985
Dean,
Thanks for the link, at least I'm not alone in this. I'll take a look at the tranny bypass (so to speak). Any real world advice? Just seemed very strange taking a transmission fluid bath instead of changing my Trans fluid.
vandalizer
Aerostar
May 7, 2012 06:18 AM
wbuffetjr1
Apr 28, 2011 07:16 PM
billj6
1983 - 2012 Ranger & B-Series
May 10, 2008 06:42 PM
Garff
Aug 2, 2005 10:01 AM
wlihntr
Feb 24, 2004 05:18 PM
