sheared distributor
Old Sep 16, 2003 | 03:07 PM
ksvtwin's Avatar
ksvtwin
sheared distributor
I have a 1986 Ford F150 with 300 six cylinder. approximately 140,000 miles. I have sheared the pin in the distributor twice inthe last year. Does anyone have any idea what could be causing this? Could it be that the oil pump is stiff?? Is it the cam?? Thanks, Kent
Old Sep 16, 2003 | 06:54 PM
mrit's Avatar
mrit
sheared distributor
Do you have a high volume/high pressure oil pump? Those put alot of stress on the pins, dist gear, oil pump driveshaft.
Old Sep 16, 2003 | 08:19 PM
Syl1's Avatar
Syl1
sheared distributor
Did the same thing twice my self/ Both times on the road. You prob have a bad bushing in the dist itself. Pep Boys $54.00 for a recond dist.
Old Sep 17, 2003 | 07:23 AM
ksvtwin's Avatar
ksvtwin
sheared distributor
Sorry guys, I should have given more information...good ideas though. The oil pump and engine are bone stock with about 140,000 miles. When the first pin sheared, the distributor did feel worn out so I replaced it with a rebuilt distributor. Then the pin on the rebuilt distributor sheared off a couple months after. I'm just kind of waiting for it to happen again. Could it be the cam walking back and forth?
Old Sep 17, 2003 | 09:34 AM
Big Orn's Avatar
Big Orn
sheared distributor
I'm with mrit. I think it's your oil pump getting ready to go out. I too had this problem with one of my trucks and replaced the dist 3 times before I finally replaced the oil pump.
Next time, when you pull your dist, and the oil pump's driveshaft is still in place, put a socket and extension on it and see if the pump is hard to turn by hand or if it has hard spots in it. You have to have patience in doing this, however. It could take a few turns to really get the feel of it.
Kentwa
22
Nov 17, 2010 07:39 AM
canucksfan
2004 - 2008 F150
21
Mar 15, 2009 05:49 PM
darrin1999
Mar 1, 2008 10:59 PM
ksvtwin
1983 - 2012 Ranger & B-Series
18
Dec 27, 2004 02:12 PM
Hegemon
New York Chapter
Mar 31, 2004 06:42 PM
