7.3 excursion died not cps?
Old Mar 5, 2018 | 01:10 PM
T-wood's Avatar
T-wood
i started this thread in the diesel forum a week ago.
My excursion has 115k no chip, ais filter and hutchmod. Stock except for that. I replaced the fuel filter last Sunday, passenger fuel line 3 weeks ago. Icp sensor maybe 2 months ago. It cranks but will not start. No sputter or smoke.
On Monday It died on my wife after driving maybe 30-40 miles after filter change. I had cycled key on off a few times and started it after changing the filter on Sunday. Since then I have replaced cps, ipr, disconnected icp. It shows no codes. Fuel pressure ko was 60psi. I gutted the stand pipe in fuel bowl. I have an extra fpr kit and considered servicing it but my fuel pressure was fine.
Ok it's been brought to my attention that it may be a pats thing. An excursion thing. The theft light does not flash fast. But I hear a click from fuse box area once the starter begins to spin and once it stops. I don't hear this in my non pats 2003 7.3 work truck. Has anyone experienced a no start on their 7.3 excursion and found that it was the pats system?
Old Mar 5, 2018 | 03:44 PM
agsmv1's Avatar
agsmv1
I think it only flashes fast when the PATS is preventing the truck from starting. Since you have no chip I do not think it is the PATS. In case it is and you want to try to reset it. I think these are the steps I used in the past. Every so often I had trouble with my tuner and it would cause the PATS to keep my truck from starting.
1. Turn the key on, but do not attempt to start the vehicle.
2. Wait for the theft light to quit flashing rapidly. This should take about 45 seconds, after which the THEFT light will flash multiple times about every 3 seconds.
3. Turn the key off and remove the key from the ignition for 30 seconds.
4. Insert the key and turn the ignition to the ON position.
5. The THEFT light should illuminate for about 5 seconds and then go out.
6. Continue to start the vehicle normally.
Have you checked the fuses? The heater in your fuel bowl can blow a fuse and keep your truck from starting...That happened to me once.
Old Mar 5, 2018 | 05:17 PM
01__Excursion's Avatar
01__Excursion
Wasn't it mentioned somewhere that a functional CPS will allow the tachometer to show something like 100 RPM when cranking?
Re-trace your all your steps, when I first got my 7.3, it would randomly surge after starting, and sometimes not start. In my case It was simply a matter of replacing some of the pigtail plugs for some of the various sensors, some sensors too. ICP, EOT, EOP, and CPS, Ect. Especially the EOT, that was the sole reason my engine was surging.
andrew4g63
24
Mar 28, 2013 06:43 PM
rbi
Apr 4, 2012 07:16 AM
ralphy_2002us
Dec 8, 2010 06:46 PM
1468LP
Nov 27, 2010 06:53 PM
mpinksto
Jan 24, 2009 09:46 PM
