7.3 died while driving
Old Apr 3, 2012 | 06:13 PM
rbi's Avatar
rbi
02 f350 7.3 w/ dp tuner.
Just died while driving with no warning, won't re-fire. First thought tuner went out, but disconnected and still nothing. All dumby lights are on. Next thoughts are camshaft position sensor or dead ecm. I know this is now a lot to go on, just wondered if there are any ideas to go with before towing to mechanic/dealer.
Thanks in advance
Old Apr 3, 2012 | 06:22 PM
Kajtek1's Avatar
Kajtek1
That happened to me a month ago. I always start troubleshooting with checking the fuel in the bowl and it was dry. I poked around the engine, shake the fuel pump under the cabin and on turning on the ignition the fuel filled up the bowl. Dry high pressure fuel line don't prime easy, so I finally used starting fluid. I made over 2000 miles since the incident and still scratch my head what was it. Think loosed plug at the pump.
For CPS troubleshooting, observe tachometer while cranking. If it is moving, than CPS sends signal. Not full diagnosis, but gives you some indication.
Old Apr 4, 2012 | 02:41 AM
carltonwebb's Avatar
carltonwebb
Do u have a wait to start light when u turn the key on? If not, it could have blown the fuse for the fuel bowl heater. I do not know what number for a 2002. But check them all including the maxi fuses of that is the case. If your find one blown, unplug the fuel heater and replace it. That is if you are missing the wts light.
Old Apr 4, 2012 | 06:54 AM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old Apr 4, 2012 | 07:16 AM
Ponyboychris's Avatar
Ponyboychris
Try unplugging the tuner to rule out a bad connection.
timtheiceman
21
Mar 7, 2018 10:48 AM
T-wood
Mar 5, 2018 05:17 PM
andrew4g63
24
Mar 28, 2013 06:43 PM
FirstTimeDiesel
Nov 16, 2011 12:25 PM
ralphy_2002us
Dec 8, 2010 06:46 PM
