Torque specs.
Old Mar 4, 2018 | 01:28 PM
jiggity76's Avatar
jiggity76
Torque specs.
Hey guys, I was wondering what the lug nut torque specs are for the 18 inch aluminum chrome clad rims for when I do my next tire rotation. What's the best way to take off the center caps or do they need to come off at all to take off the lug nuts? Here's a pic of my 17 F250 and the rims/center cap I'm referring too.
Old Mar 4, 2018 | 01:57 PM
HRTKD's Avatar
HRTKD
155 lb ft on the lug nuts. Hub cap can be removed using the rubber coated end of the lug wrench that is under your back seat.
Old Mar 4, 2018 | 01:58 PM
C12H24's Avatar
C12H24
Pages 416 through 420 in your owner's manual. Caps can remain but if you need to remove them, there's a tool in the jack bag.
Old Mar 4, 2018 | 04:08 PM
jiggity76's Avatar
jiggity76
Thank you guys, never even thought of the manual! Dealership put a little gouge in one of the rims when they did it last time so that's why I want to do from now on.
Old Mar 4, 2018 | 04:28 PM
CopterPilot's Avatar
CopterPilot
Did the specs change from previous years? I was under the impression they were 165 ft lbs on the lugs.
Old Mar 4, 2018 | 05:09 PM
jiggity76's Avatar
jiggity76
I'm going to look thru my manual and see if I can find anything on it and then I'll post and confirm.
Old Mar 4, 2018 | 06:31 PM
2009kr's Avatar
2009kr
My 2017 F450 is 165 ft lbs, and you put a small drop of oil behind the washer.
Old Mar 4, 2018 | 09:12 PM
crewzer's Avatar
crewzer
Lightbulb
165 lb.ft according to the 2017 OM (v3), page 413.
For single rear wheel vehciles, check torque again 100 miles after "wheel disturbance" (e.g., rotation). For DRW trucks, check at 100 miles and again at 500 miles.
HTH,
Jim / crewzer
Old Mar 4, 2018 | 10:18 PM
HRTKD's Avatar
HRTKD
HTH,
Jim / crewzer
^^^ What he said. I didn't remember it right. I looked at an older version of the manual it was 165 there also. So I don't think the spec has changed.
68-F250-4x4
18
Apr 30, 2023 01:57 PM
bedwards
2015 - 2020 F150
16
Nov 20, 2018 07:18 PM
jmgekeler
May 2, 2010 09:01 AM
cbfomoco
Feb 10, 2007 11:05 AM
77Lance
Feb 24, 2005 07:06 PM
