Loose Lug Nuts??!!
Old May 1, 2010 | 09:31 PM
jmgekeler's Avatar
jmgekeler
Loose Lug Nuts??!!
I was driving down the road today, when all of the sudden the front right tire started knocking. So I stopped to look what was up. One lug nut was missing, three more where almost completely unthreaded and the other 4 were slightly loose. Figured I'd better check the other tires and found the front left were also loose, but not as bad. Luckly, there was no damage and all is well now.
So the question is, can the lugs just loosen up on American Racing rims, or did someone try to steel my wheels?
-Jason
Old May 1, 2010 | 09:33 PM
Talyn's Avatar
Talyn
yea, improperly torqued lugnuts can loosen on rims.
I cannot remember if its steel or aluminum ones they like to loosen up on though.
Some rims you have to torque them, take them for a drive and torque them again.
Old May 1, 2010 | 09:57 PM
fordpride's Avatar
fordpride
on a aluminum you should torque them when you frist put them on and then after 500 miles. my brother and law had one of his coom off of his SD.
Old May 2, 2010 | 05:22 AM
WALJON's Avatar
WALJON
Yes if you just had the tires off and were not torqued after the first drive, I have had this happen not to long ago on my wife's SUV but I ended up buying a new rim because the lug holes were egg shaped LOL
Old May 2, 2010 | 09:01 AM
jmgekeler's Avatar
jmgekeler
I didn't have the rims off but the guy I bought it from probably did. I can honestly say that I have never had lugs come loose from a rim. Even aluminum mag rims. But I guess you learn something new everyday. I can use this an excuse to buy nice torque wrench! How are the craftsman torque wrenches?
93 mix 'n match
1997 - 2003 F150
Feb 18, 2010 10:08 PM
skoveng
Aug 12, 2009 10:10 AM
Fordenthusiasts
21
May 14, 2009 04:31 PM
Gil Chesterton
Feb 9, 2006 01:10 PM
rabidranger
Dec 18, 2003 12:45 AM
