Sponsored by: Kumho
Lug nuts vibrating lose?
Old Feb 23, 2005 | 01:21 PM
77Lance's Avatar
77Lance
Last summer I changed over my tires to 33 12.5R15 on Steel rims but the rims are 7" wide rims. I have been saving up for a safer wider set of rims. Since last month I have been noticing that the driver's side rear and both fronts, lug nuts are backing off the studs. I am regularly tighting them back on but I have broken two on the front, completely off. -- I didn't notice my air pressure on the gun was pretty high.
Any thoughts on way my lugs on coming lose?
Thanks !!!
Old Feb 23, 2005 | 01:25 PM
Brian794x4's Avatar
Brian794x4
You need to properly torque them my friend. Especially if they are giving you a hard time. 100 Ft #'s and you should be golden. Steel wheels shouldnt need retorqued, but do it anyways after 100 miles. And replace those lug nuts. I did tires for a couple years and didnt have a problem with nuts comming loose other then new alloys. Good luck
Brian
Old Feb 24, 2005 | 08:07 AM
77Lance's Avatar
77Lance
Thanks
I will be using a torque wrench and not rely on my air gun for proper torque setting.
Old Feb 24, 2005 | 07:06 PM
rebocardo's Avatar
rebocardo
Make sure you are using acorn type lug nuts and the wheels have a tapered seat for the acorn lug nuts and do not not have a flat surface where the lug nuts seat.
