Polyurethane Coil Spacers Questions
Old Mar 3, 2018 | 11:18 AM
95fiveoh's Avatar
95fiveoh
My 1995 f150 sits a bit lower in the front than in the rear, as is normal for these trucks. However the previous owner also installed some lift blocks between the rear axle and leaf springs in the rear, so the forward rake is even steeper. I am wanting to lift the front up just a little bit to level the truck out slightly closer to the factory stance. I want to use some 2 inch polyurethane Coil Spacers.
For anyone who has used them before, is there ant difference between the daystar brand spacers and the cheaper eBay spacers? Anything else I should know before installing them? The truck needs an alignment anyway, so I will be getting one after installing these.
Old Mar 3, 2018 | 04:22 PM
Binkowski's Avatar
Binkowski
This thread might give you a better idea. Just change the springs.
https://www.ford-trucks.com/forums/1...-question.html
Old Mar 3, 2018 | 08:58 PM
95fiveoh's Avatar
95fiveoh
Wow, thanks for that. Moog 844s seem like the way to go! I'll be ordering a pair soon.
Old Mar 3, 2018 | 10:55 PM
McLeod's Avatar
McLeod
FYI:
Ford installed ~2 " lift blocks on the trucks.
If the blocks have the protrusions out the side to contact the bump stop, they are the factory ones.
It is to keep the truck level with a slight load in the bed.
badgerbrock
Offroad & 4x4
Aug 27, 2007 09:37 PM
1987fi50
Mar 21, 2006 10:54 AM
broncodude3
Bronco II
Nov 13, 2003 01:42 PM
ZERO
1983 - 2012 Ranger & B-Series
Oct 28, 2003 08:29 PM
mnm1997
1978 - 1996 Big Bronco
Dec 28, 2000 06:18 PM
