1994 Barn find
Old Feb 28, 2018 | 07:53 PM
chaser1602's Avatar
chaser1602
1994 Barn find
A 94 f150 reg cab long bed 5.0 auto trans, 69,000 miles. woohoo
Now the problem. Sat 3 yrs full of gas. Had to take care of that issue to get I started. Now its running. Rough/missing. 65 mph downhill with a tailwind and not running on all cylinders. Considering the gas I figure there are some plugged up injectors. Possible? Pulled plugs and looks like it might have been running on 4 cylinders and put 8 new ones in. Still thinking injectors so ordered new ones. After I changed plugs I started it and it ran fairly smooth. CEL comes on. Found fuel regulator vac line off. Plug it back in and starts running like it did when I brought it home. Somewhat smoother but still rough and spitting out the intake. So it must be running rich I'm thinking. Should I be looking at the fuel regulator or keep going with the plugged injector idea?
Old Feb 28, 2018 | 08:40 PM
rla2005's Avatar
rla2005
My 1990 garage queen has original plug wires. Newer cap, rotor and plugs but the wires are shot. Never overlook the obvious.
Old Mar 1, 2018 | 05:29 PM
Workingstiff's Avatar
Workingstiff
I agree check out plugs and wires etc....
Old Mar 1, 2018 | 06:06 PM
rla2005's Avatar
rla2005
And pull the codes.
Old Mar 1, 2018 | 07:07 PM
SpeedThrills's Avatar
SpeedThrills
Look for vacuum leaks.
Old Mar 1, 2018 | 07:09 PM
yardbird's Avatar
yardbird
There is always the possibility it was parked running that way.
Old Mar 8, 2018 | 07:20 PM
chaser1602's Avatar
chaser1602
New plugs and injectors and runs fine.
Now when I switch to the front tank it runs out of fuel. It'll run for a short time. Has fuel. Its full. I put it in there. Pump is running. Must have some sort of blockage.
Any ideas were to look?
Old Mar 8, 2018 | 08:39 PM
Scndsin's Avatar
Scndsin
I see no mention of a fuel filter change?
Old Mar 9, 2018 | 05:26 AM
chaser1602's Avatar
chaser1602
Changed filter when I was trying to get it running.
Old Mar 9, 2018 | 07:10 AM
Scndsin's Avatar
Scndsin
Did you by chance empty it out to see what it caught?
(edit) Have codes been run?
Does pump run 1-2 seconds, then shut down when key is turned to run, but not not started or runs continuously?
Old Mar 9, 2018 | 07:53 AM
chaser1602's Avatar
chaser1602
Gas. Small amount of water. Was not plugged up like I thought it would bee. Blew through it wasn’t to bad. It sat for @ year full of fuel
oh2bnok
1983 - 2012 Ranger & B-Series
Jul 6, 2010 09:14 AM
86stepsideF150
64
May 17, 2009 04:44 PM
thomadm
Jan 6, 2007 05:06 PM
Stevie M
Aerostar
Dec 29, 2003 01:20 PM
Snatch Block
Aug 27, 2003 06:13 AM
