Injectors??
Old Aug 25, 2003 | 06:24 AM
Snatch Block's Avatar
Snatch Block
Angry Injectors??
Here is the deal, I am getting crappy Km's from a tank of gas, I replaced the regulator cause I thought it was running too rich. I pull a couple of the plugs out and all I smell is gas & the plugs are wet. Not all plugs are like this, some are burning good. I think that the injectors are finished, what you you guys think?
Old Aug 26, 2003 | 10:28 PM
LxMan1's Avatar
LxMan1
Injectors??
Sounds like they could be dirty or fauly and not shutting off completely causing fuel to drip into the cylinders.
Could be weak spark plugs or wires too, but probably the injectors.
Jimmy
Old Aug 27, 2003 | 06:13 AM
Snatch Block
Unhappy Injectors??
Did a tune up around 4 months ago, so it is not the plugs or wires.
Thanks.
