Brake Problem
Old Feb 28, 2018 | 05:50 PM
McBrider621's Avatar
McBrider621
Brake Problem
Hey guys recently got into some brake trouble, was towing a trailer small enclosed 6x12 when I turn around and see my driver side brake smoking like crazy at a stop light. So pulled over and the brake was sure enough locked up, terrible burning smell I dont know what happened. Anyways brake locked up and i popped off the wheel got it free made it home. I obviously replaced the caliper, I got to take the truck out today and the same burning smell is happening from the same tire with smoke I dont whats going on what else could be the problem if it isnt a sticking caliper??? Im really lost as I thought for sure that was the problem. Thanks..Just not sure what to look into next.
Old Feb 28, 2018 | 07:32 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
If it got that hot, you will need to completely flush the brake fluid from the rear lines. I'm talking a COMPLETE fluid change here. Then you will need to replace the rubber line running from the hard line to the caliper. I would take the next step, and replace all the soft lines in the rear if they are original. It is most likely collapsed/failed inside, and it is not letting the fluid retreat from the caliper when you let off the brake.
Old Feb 28, 2018 | 08:08 PM
SmackDaddy's Avatar
SmackDaddy
IF you replace those lines you might go one step further and upgrade to Russell braided stainless steel brake lines for about $150 for the whole set.
Rusty_S
Feb 20, 2015 06:56 AM
NC2X4
15
Aug 31, 2010 10:48 PM
2001 7.3
Jan 30, 2010 03:54 PM
bigk_54
Nov 14, 2007 08:24 PM
donna
Jul 20, 2000 11:03 PM
