Discontinued accelerator cable
Old Feb 28, 2018 | 03:17 PM
doctoss's Avatar
doctoss
My 2001 Navigator has a frayed accelerator cable. The part is xL7z*9a758*AA which has been discontinued. The 2001 expedition cable is xL1z*9a758*EA and the dealer referred me to do an internet search? Any experience with a substitute cable? Thanks
Old Feb 28, 2018 | 05:25 PM
Beechkid's Avatar
Beechkid
any of the major auto parts stores should be able to get one for you...another option is to pull your current cable out (just the cable) and visit a local motorcycle shop...they will have a variety of cables sitting at their store for "universal" applications....
Old Feb 28, 2018 | 08:32 PM
doctoss's Avatar
doctoss
Thanks, will look and see, may try a pull parts salvage.
Old Mar 1, 2018 | 12:31 PM
rla2005's Avatar
rla2005
https://www.tascaparts.com/oem-parts...le-xl1z9a758ea
Old Mar 2, 2018 | 07:04 AM
alwaysfords41's Avatar
alwaysfords41
Well that was easy.
Old Mar 2, 2018 | 08:23 AM
doctoss's Avatar
doctoss
I wish it were that easy. That was the same part that the dealer had, but said they were not sure it would fit. The link given above says it does not fit the 2001 Navigator, as this is the cable for the 2001 Expedition. I have been busy at work this week, I think I will remove the old cable and take it to Autozone or such. I should have a better idea after I remove it. Thanks .
Old Mar 2, 2018 | 08:32 AM
alloro's Avatar
alloro
These people seem to have a used one for $15.
Search Results=
Old Mar 2, 2018 | 08:53 AM
rla2005's Avatar
rla2005
You are correct, I grabbed the wrong Part Number from your post. I found another reliable source that lists XL7Z9A758AA as fitting Expedition 5.4L and DOHC. Makes you wonder if the XL7Z9A758EA is the replacement?
Definitely a good idea to take your old one with you for comparison.
Old Mar 2, 2018 | 11:20 AM
doctoss's Avatar
doctoss
Search Results=
Thanks, this one looks promising.
Old Mar 3, 2018 | 12:52 PM
doctoss's Avatar
doctoss
Search Results=
I think you hit the jackpot. I called them, Greear's Used Parts and they were very nice, correct part and they are sending it to me for $20. After I took mine out I was not real excited about going to a local Pull a Part and doing that again. Thanks.
Old Mar 3, 2018 | 04:37 PM
alloro's Avatar
alloro
Well if it's wrong you can always sell in on eBay for $30.
Old Mar 10, 2018 | 10:32 AM
doctoss's Avatar
doctoss
Search Results=
Thanks greatly. They had the correct part. Strangely when I pulled my cable, it was not the part Ford says was the replacement. My part and the part from the used parts dealer was xL74-9a758-AE which I could not find on the internet, but it is the correct one for my 2001 Navigator. Thanks guys.
Old Mar 10, 2018 | 11:43 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
My 2001 Navigator has a frayed accelerator cable. The part is XL7Z-9A758-AA which has been discontinued.
The 2001 expedition cable is XL7Z-9A758-EA and the dealer referred me to do an internet search?*
No one on internet obsolete search sites PartsVoice.com & rearcounter.com has either cable.
About 25% of the US FoMoCo dealers are listed on PartsVoice as are the obsolete parts vendors. rearcounter has one Ford dealer and some of the obsolete parts vendors listed.
ANYONE can access these two sites. But when you type part numbers on these two sites, REMOVE any spaces or hyphens, type 'em like this: XL7Z9A758AA
*Did the partsguy at the dealer look on the Ford D2D (Dealer to Dealer-FoMoCo Dealer Parts Locator System) to see if anyone had any? As usual, probably not.
If you found a number on the cable, it is NOT the part number! It's the ID engineering number. Dealers can cross ID engineering numbers over to Ford part numbers.
aapropane
Nov 13, 2017 10:49 AM
BPofMD
Maryland Chapter
Sep 17, 2017 10:19 AM
CNC
May 5, 2009 05:04 PM
