1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Discontinued accelerator cable
Old 02-28-2018, 03:17 PM
doctoss's Avatar
doctoss
doctoss is offline
My 2001 Navigator has a frayed accelerator cable. The part is xL7z*9a758*AA which has been discontinued. The 2001 expedition cable is xL1z*9a758*EA and the dealer referred me to do an internet search? Any experience with a substitute cable? Thanks
Old 02-28-2018, 05:25 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
any of the major auto parts stores should be able to get one for you...another option is to pull your current cable out (just the cable) and visit a local motorcycle shop...they will have a variety of cables sitting at their store for "universal" applications....
Old 02-28-2018, 08:32 PM
doctoss's Avatar
doctoss
doctoss is offline
Thanks, will look and see, may try a pull parts salvage.
Old 03-01-2018, 12:31 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,194 Likes on 943 Posts
Old 03-02-2018, 07:04 AM
alwaysfords41's Avatar
alwaysfords41
alwaysfords41 is offline
Well that was easy.
Old 03-02-2018, 08:23 AM
doctoss's Avatar
doctoss
doctoss is offline
I wish it were that easy. That was the same part that the dealer had, but said they were not sure it would fit. The link given above says it does not fit the 2001 Navigator, as this is the cable for the 2001 Expedition. I have been busy at work this week, I think I will remove the old cable and take it to Autozone or such. I should have a better idea after I remove it. Thanks .
Old 03-02-2018, 08:32 AM
alloro's Avatar
alloro
alloro is offline
Received 4,254 Likes on 2,480 Posts
These people seem to have a used one for $15.
Search Results=
Old 03-02-2018, 08:53 AM
rla2005's Avatar
rla2005
rla2005 is offline
You are correct, I grabbed the wrong Part Number from your post. I found another reliable source that lists XL7Z9A758AA as fitting Expedition 5.4L and DOHC. Makes you wonder if the XL7Z9A758EA is the replacement?
Definitely a good idea to take your old one with you for comparison.
Old 03-02-2018, 11:20 AM
doctoss's Avatar
doctoss
doctoss is offline
Search Results=
Thanks, this one looks promising.
Old 03-03-2018, 12:52 PM
doctoss's Avatar
doctoss
doctoss is offline
Search Results=
I think you hit the jackpot. I called them, Greear's Used Parts and they were very nice, correct part and they are sending it to me for $20. After I took mine out I was not real excited about going to a local Pull a Part and doing that again. Thanks.
Old 03-03-2018, 04:37 PM
alloro's Avatar
alloro
alloro is offline
Well if it's wrong you can always sell in on eBay for $30.
Old 03-10-2018, 10:32 AM
doctoss's Avatar
doctoss
doctoss is offline
Search Results=
Thanks greatly. They had the correct part. Strangely when I pulled my cable, it was not the part Ford says was the replacement. My part and the part from the used parts dealer was xL74-9a758-AE which I could not find on the internet, but it is the correct one for my 2001 Navigator. Thanks guys.
Old 03-10-2018, 11:43 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
My 2001 Navigator has a frayed accelerator cable. The part is XL7Z-9A758-AA which has been discontinued.
The 2001 expedition cable is XL7Z-9A758-EA and the dealer referred me to do an internet search?*
No one on internet obsolete search sites PartsVoice.com & rearcounter.com has either cable.
About 25% of the US FoMoCo dealers are listed on PartsVoice as are the obsolete parts vendors. rearcounter has one Ford dealer and some of the obsolete parts vendors listed.
ANYONE can access these two sites. But when you type part numbers on these two sites, REMOVE any spaces or hyphens, type 'em like this: XL7Z9A758AA
*Did the partsguy at the dealer look on the Ford D2D (Dealer to Dealer-FoMoCo Dealer Parts Locator System) to see if anyone had any? As usual, probably not.
If you found a number on the cable, it is NOT the part number! It's the ID engineering number. Dealers can cross ID engineering numbers over to Ford part numbers.
aapropane
1999 to 2016 Super Duty
11-13-2017 10:49 AM
BPofMD
Maryland Chapter
09-17-2017 10:19 AM
CNC
05-05-2009 05:04 PM
Quick Reply: Discontinued accelerator cable
