Sponsored by: Real Truck
Outside door handle
Old Feb 28, 2018 | 12:41 PM
Lawnpro979's Avatar
Lawnpro979
Outside door handle
On my 2000 SD
the door handle has stopped going back in. at 1st it just refused to go back in but the door would latch.
I ignored it for a week or so, and now it wont latch, The latch looks ok, but i cam play with it with a screwdriver and it will latch...
wondering if anyone knows how to fix, b4 I tear into it and screw things up?
Also. There’s a rubber plug. I’m wondering if thats some sort of access hole to help me fix this
thx...
Old Feb 28, 2018 | 01:20 PM
brandon_oma#692's Avatar
brandon_oma#692
I took mine off cleaned, lubed, and reinstalled. 360 days later stuck again. Bought the cheapest on ebay and all good now.
Edit 1 nut is accessed thru the rubber plug in your picture. THe other you need to remove the door panel to get to.
Old Feb 28, 2018 | 01:23 PM
seville009's Avatar
seville009
Was going to suggest generous amounts of WD-40
Old Feb 28, 2018 | 02:59 PM
Lawnpro979's Avatar
Lawnpro979
Thx..... yes I sprayed it down pretty good with wd, about a week ago.
did you just order a new outside handle?
or is there something on the inside I need?
I live in the country it takes us about 2 weeks to get anything. If I tear it apart and need something else. I'm kind of screwed
thx again
Old Feb 28, 2018 | 03:17 PM
seville009's Avatar
seville009
Maybe take it apart first just to take a look at it. Maybe you’ll get lucky and find the part that needs to be replaced, which you could probably identify on an exploding parts diagram on a parts website.
This is a youtube video showing someone taking it apart.
Old Feb 28, 2018 | 03:31 PM
brandon_oma#692
Door handles are about $10 each shipped. just replace all 4 and be done. Not worth the time to clean and lube in my opinion. THe fronts I bought from a different seller and are a little nicer than the back. back were installed in July 2016 and fronts 2017 when one stuck and I had to tear the door apart 3 hours from home so the wife could shut the passenger door lol.
Old Feb 28, 2018 | 04:07 PM
Lawnpro979's Avatar
Lawnpro979
Got it.....thanks again guys....
Old Mar 1, 2018 | 07:15 AM
m-chan68's Avatar
m-chan68
For what it's worth, it only takes two 7mm fasteners to be removed, and the door panel is off, giving you plenty of access to determine the faulty part.
Idaho Highboy
Jan 12, 2019 06:53 PM
Kecky
Apr 23, 2018 04:23 PM
ericthor
22
Oct 13, 2016 04:54 PM
gdub
Jan 3, 2014 09:53 PM
shooer
Apr 10, 2008 06:17 PM
