All,
i have had a serious issue with my EX. The OD light will come on and flash sometimes when I come to a stop. When it does happen it tries to stall out and when I start going it changes hard into second gear. Also sometimes when this happens it is like all the electronic accessories turn off. The key is turned on still so the at is odd. The radio will completely shut off and turn back on. I had the radio changed out around the time this started happening but not sure if this could contribute to this. I took it to a Ford Dealership and below is a list of parts they have replaced. Any help sure is appreciated.
Speed control module on differential
solenoid packs
Transmission
PCM
Alternator
Battery
GEM Module
Thanks for the reply. I live near Jackson, Mississippi. The Ford tech put an on board recorder and basically got the same codes. I believe they were P0720 and P0722.
Sorry, I don't know any shop within a reasonable distance of you. What you need to do is find an independent shop that specializes in electrical diagnosis. Something is playing havoc with the electrical system in your truck.
Since it started about when you replaced the radio I think it would be worth a try to unplug each connection from the radio and see if the truck drives any differently.
It sounds like you have a coil out. The same happened to me. The rear coils get wet and will short out. The other 9 compensate somewhat but you still have a dead hole.
