Trailer mounted camera help
Old Feb 25, 2018 | 05:39 PM
SmokyOkie's Avatar
SmokyOkie
Does anyone have a link where I can print off an owner's manual for my trailer mounted back up camera?
Also, I just picked up my trailer from the trailer builder. They mounted and wired the camera system, but it doesn't work. When I push the auxiliary camera button, it shows an icon of a camera with a line through it ( as if to say no camera installed). Does anyone have any suggestions as to how to trouble shoot it?
Any and all help appreciated!
Old Feb 25, 2018 | 06:10 PM
Robeleo's Avatar
Robeleo
Only works when you put in reverse, I don't know if you're aware of that
Old Feb 25, 2018 | 06:16 PM
SmokyOkie's Avatar
SmokyOkie
Yes, I am aware of that. Put it in reverse, tap the AUX icon, and it shows an icon of a camera with a line through it as if to say there is no camera.
Bill_The_PA's Avatar
Bill_The_PA
also even ford technicians tried hookin it up using the tailgate wires. Make sure you look to see if they hooked it up to the harness that sits above the spare tire.
Old Feb 25, 2018 | 06:18 PM
Bill_The_PA
If there is a wire harness above the spare then they hooked it up wrong.
Old Feb 25, 2018 | 06:20 PM
SmokyOkie's Avatar
SmokyOkie
I dropped the spare and there was nothing directly above it. I found a harness and unused plug in front and above the spare zip tied on the frame. It appeared to be the only unused plug there and it fit the other end.
Old Feb 25, 2018 | 06:21 PM
SmokyOkie's Avatar
SmokyOkie
The only harness I found was zip tied onto the frame above and behind the spare. It was the correct type of plug, so I assumed it to be the right one.
Old Feb 25, 2018 | 06:24 PM
Bill_The_PA
That’s the one
Old Feb 25, 2018 | 06:25 PM
Bill_The_PA
Should be a 12 or 15 pin.
Old Feb 25, 2018 | 06:26 PM
Bill_The_PA
Plug that into the rear of the harness ( part of the 7 was pin on the bumper)
Old Feb 25, 2018 | 06:27 PM
SmokyOkie's Avatar
SmokyOkie
I believe 12 pin. I drove back to Texas from Phoenix with it, just crawled under the truck and the trailer both and can't find any loose connections. No idea why it won't work.
Old Feb 25, 2018 | 06:28 PM
SmokyOkie's Avatar
SmokyOkie
I removed the old 7 round/4 flat plug in from the bumper and connected the new one to the plugs on the truck, checked both to make sure they were fully connected.
Old Feb 25, 2018 | 06:32 PM
Bill_The_PA
so just to be clear you’ve now hooked up the harness you found ( zip tied to the frame ) and your camera still doesn’t work.
Old Feb 25, 2018 | 06:35 PM
Bill_The_PA
David Smiley did a video on you tube. Maybe that will help. Can’t remem if you need to make any settings in The advanced settings. Don’t think so. Sorry man not much I can do from here in Canada.
Old Feb 25, 2018 | 06:44 PM
SmokyOkie's Avatar
SmokyOkie
I did that as part of the initial install before I even tried to use it.
